.NET
Rotate Problem
4 REPLIES 4
475 Views, 4 Replies
Rotate Problem
Hi, Guys.
I made a rotate function, but got error message.
How should I fix it? Attached file.
Plz,help me.
4 REPLIES 4
See atached.
Work for me.
tp
escreveu na mensagem news:5431387@discussion.autodesk.com...
Hi, Guys.
Plz,help me.
I'm protected by SpamBrave
http://www.spambrave.com/
Thank you very much for your kindness reply.
Then, work for you? Work what?
If private comment, email me below.
gilseorin@naver.com
You need to use Transaction to open entity for write (not for read, as in
your code), and then commit the change (rotation transform) by calling
Transaction.Commit(). That is the difference between your code and the
working ocde replied by tp (have you actually read his code?).
wrote in message news:5431954@discussion.autodesk.com...
gilseorin@naver.com
Thank you so much.
Finally,owing to the function provided by tp and your advice , I succeeded to perform a rotate method in vb.net.
Happy Day!
”Boost
