.NET
Valued Contributor
Ron_M
Message 1 of 13 (195 Views)
Rotate Prior to Insertion of Block
195 Views, 12 Replies
05-02-2014 08:00 AM
ACA 2014, WIndows 7 64, VS 2013 Express, VB.Net
The block library is coming along well and I'm at a point where one further push or assist should allow me to complete it.
At this time blocks are pulled from external drawings, shown on the cursor as it moves on the screen, rotate on the cursor prior to input, BUT insert at the original orientation.  I am confused on how to pass back to InsertBlock the rotation angle of the block as shown on the cursor and have the block inserted at that orienation rather than at the original.  Below are the code for my library and the jig.
Library.vb
Imports System
Imports System.IO
Imports System.Windows.Controls
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Public Class Library
    Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
    Dim itemstr As String
    Dim ed As Editor
    Private Sub Library_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        For Each i As String In Directory.GetDirectories("R:\2014\Library\")
            ListView1.Items.Add(Path.GetFileName(i))
        Next
        ListView1.Items.Remove(ListView1.Items(0))
        If ListView1.Items.Count > 0 Then
            ListView1.Items(0).Focused = True
            ListView1.Items(0).Selected = True
            itemstr = (Me.ListView1.FocusedItem.Text)
            PictureBox1.ImageLocation = ("R:\2014\Library\" & itemstr & "\template.wmf")
        End If
    End Sub
    Private Sub ListView1_SelectedIndexChanged(sender As Object, e As EventArgs) Handles ListView1.SelectedIndexChanged
        If Me.ListView1.SelectedItems.Count > 0 Then
        End If
    End Sub
    Private Sub PictureBox1_MouseClick(sender As Object, e As System.Windows.Forms.MouseEventArgs) Handles PictureBox1.MouseClick
        Dim xPos As Integer
        Dim yPos As Integer
        If e.Button = System.Windows.Forms.MouseButtons.Left Then
            xPos = e.X
            yPos = e.Y
        End If
        doit(xPos, yPos, itemstr)
    End Sub
    Private Sub doit(ByVal xPos As Single, ByVal yPos As Single, itemstr As String)
        Dim box As String
        Dim x As Integer
        Dim y As Integer
        Dim layer As String
        x = (Int(xPos / 100))
        y = (Int(yPos / 100))
        If y > 0 Then
            box = (Int((x) + (Int(y) * 8)))
        Else : box = x
        End If
        'Layers
        Using Myreader As New Microsoft.VisualBasic.FileIO.TextFieldParser("R:\2014\Library\" & itemstr & "\layers.lst")
            Myreader.TextFieldType = FileIO.FieldType.Delimited
            Myreader.SetDelimiters(",")
            While Not Myreader.EndOfData
                Try
                    Dim fields() As String = Myreader.ReadFields
                    layer = (fields(box))
                Finally
                End Try
            End While
            AddLayer(layer)
        End Using
        'Blocks
        Using Myreaderblocks As New Microsoft.VisualBasic.FileIO.TextFieldParser("R:\2014\Library\" & itemstr & "\library.lst")
            Myreaderblocks.TextFieldType = FileIO.FieldType.Delimited
            Myreaderblocks.SetDelimiters(",")
            While Not Myreaderblocks.EndOfData
                Try
                    Dim fields() As String = Myreaderblocks.ReadFields
                    Dim currentField As String = (fields(box))
                    If currentField.Length > 5 Then
                        result = currentField.Substring(currentField.Length - 3)
                    End If
                    Dim BlockName As String = currentField.Substring(0, currentField.Length - 6)
                    If Not result = "" Then
                        Select Case result
                            Case "dwg"
                                addblock(BlockName, currentField, itemstr)
                        End Select
                    End If
                Catch ex As Microsoft.VisualBasic.FileIO.MalformedLineException
                End Try
            End While
        End Using
    End Sub
    Public Sub AddLayer(layer)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        acDoc.LockDocument()
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim ltb As LayerTable = DirectCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
            'create a new layer
            If Not ltb.Has(layer) Then
                ltb.UpgradeOpen()
                Dim newLayer As New LayerTableRecord()
                newLayer.Name = layer
                newLayer.LineWeight = LineWeight.LineWeight005
                newLayer.Description = "This is new layer"
                'red color
                newLayer.Color = Autodesk.AutoCAD.Colors.Color.FromRgb(255, 0, 0)
                ltb.Add(newLayer)
                tr.AddNewlyCreatedDBObject(newLayer, True)
            End If
            tr.Commit()
            'make it as current
            db.Clayer = ltb(layer)
        End Using
    End Sub
    Public Sub addblock(ByVal blockname As String, ByVal currentfield As String, ByVal itemstr As String)
        Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
        Using OpenDb As New Database(False, True)
            OpenDb.ReadDwgFile("R:\2014\Library\" & itemstr & "\" & currentfield, System.IO.FileShare.ReadWrite, True, "")
            Dim ids As New ObjectIdCollection()
            Using tr As Transaction = OpenDb.TransactionManager.StartTransaction()
                'For example, Get the block by name "BlkName"
                Dim bt As BlockTable
                bt = DirectCast(tr.GetObject(OpenDb.BlockTableId, OpenMode.ForRead), BlockTable)
                If bt.Has(blockname) Then
                    ids.Add(bt(blockname))
                End If
                tr.Commit()
            End Using
            'if not found, add the block
            If ids.Count <> 0 Then
                'get the current drawing database
                Dim destdb As Database = acDoc.Database
                Dim iMap As New IdMapping()
                destdb.WblockCloneObjects(ids, destdb.BlockTableId, iMap, DuplicateRecordCloning.Ignore, False)
            End If
        End Using
        Dispose()
        InsertBlockWithJig(blockname, layer)
    End Sub
    Public Sub InsertBlockWithJig(ByVal blockname As String, layer As String)
        Dim myDB As Database
        myDB = HostApplicationServices.WorkingDatabase
        Dim myJig As BlockJig
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
            Dim myBT As BlockTable = myDB.BlockTableId.GetObject(OpenMode.ForRead)
            If myBT.Has(blockname) Then
                Dim myBTR As BlockTableRecord = myBT(blockname).GetObject(OpenMode.ForRead)
                myJig = New BlockJig(myBTR.ObjectId)
            Else
                Exit Sub
            End If
        End Using
        Dim myBlkID As ObjectId
        Dim SelPt As EditorInput.PromptPointResult
        Dim pdr As EditorInput.PromptPointResult
        Do
            SelPt = myJig.BeginJig
            If Not SelPt Is Nothing Then
                Select Case SelPt.Status
                    Case EditorInput.PromptStatus.OK
                        myBlkID = insertblock(SelPt.Value, blockname)
                    Case EditorInput.PromptStatus.Other
                        Exit Sub
                End Select
            End If
            If SelPt Is Nothing Then Exit Do
        Loop While SelPt.Status = EditorInput.PromptStatus.OK
    End Sub
    Public Function insertblock(BasePt As Point3d, blockname As String)
        Using myT As Transaction = db.TransactionManager.StartTransaction()
            'Get the block definition "Check".
            Dim bt As BlockTable = TryCast(db.BlockTableId.GetObject(OpenMode.ForRead), BlockTable)
            Dim blockDef As BlockTableRecord = TryCast(bt(blockname).GetObject(OpenMode.ForRead), BlockTableRecord)
            'Also open modelspace - we'll be adding our BlockReference to it
            Dim ms As BlockTableRecord = TryCast(bt(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite), BlockTableRecord)
            'Create new BlockReference, and link it to our block definition
            Using blockRef As New BlockReference(BasePt, blockDef.ObjectId)
                'Add the block reference to modelspace
                ms.AppendEntity(blockRef)
                myT.AddNewlyCreatedDBObject(blockRef, True)
                'Iterate block definition to find all non-constant AttributeDefinitions
                For Each id As ObjectId In blockDef
                    Dim obj As DBObject = id.GetObject(OpenMode.ForRead)
                    Dim attDef As AttributeDefinition = TryCast(obj, AttributeDefinition)
                    If (attDef IsNot Nothing) AndAlso (Not attDef.Constant) Then
                        'This is a non-constant AttributeDefinition
                        'Create a new AttributeReference
                        Using attRef As New AttributeReference()
                            attRef.SetAttributeFromBlock(attDef, blockRef.BlockTransform)
                            'Add the AttributeReference to the BlockReference
                            blockRef.AttributeCollection.AppendAttribute(attRef)
                            myT.AddNewlyCreatedDBObject(attRef, True)
                        End Using
                    End If
                Next
            End Using
            acDoc.TransactionManager.QueueForGraphicsFlush()
            myT.Commit()
        End Using
    End Function
End Class
 BlockJig.vb
Public Class BlockJig
    Inherits Autodesk.AutoCAD.EditorInput.EntityJig
    Dim BasePt As Point3d = New Point3d(0, 0, 0)
    Dim myMatrix As Matrix3d
    Dim myBRef As DatabaseServices.BlockReference
    Dim myOpts As EditorInput.JigPromptPointOptions
    Dim CurrentKeyword As String
    Protected _pos As Point3d
    Protected _rot As Double, _ucsRot As Double
    Sub New(ByVal BlockID As ObjectId)
        MyBase.New(New DatabaseServices.BlockReference(BlockIns, BlockID))
        myBRef = Me.Entity
        _pos = myBRef.Position
        _rot = myBRef.Rotation
    End Sub
    Function BeginJig() As PromptPointResult
        If myOpts Is Nothing Then
            myOpts = New EditorInput.JigPromptPointOptions()
            myOpts.Message = vbCrLf & "Select a point:"
            myOpts.Cursor = EditorInput.CursorType.Invisible
            myOpts.UseBasePoint = False
        End If
        Dim ed As EditorInput.Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim myPR As PromptResult
        Dim ucs As CoordinateSystem3d = ed.CurrentUserCoordinateSystem.CoordinateSystem3d
        Dim ocsMat As Matrix3d = Matrix3d.WorldToPlane(New Plane(Point3d.Origin, ucs.Zaxis))
        _ucsRot = Vector3d.XAxis.GetAngleTo(ucs.Xaxis.TransformBy(ocsMat), ucs.Zaxis)
        _rot = myBRef.Rotation - _ucsRot
        myPR = ed.Drag(Me)
        Do
            Select Case myPR.Status
                    Return myPR
                    Exit Do
                Case EditorInput.PromptStatus.None
                    Return myPR
                    Exit Do
                    Return myPR
                    Exit Do
            End Select
        Loop While myPR.Status <> EditorInput.PromptStatus.Cancel
        Return Nothing
    End Function
    Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
        Dim mods As System.Windows.Forms.Keys = System.Windows.Forms.Control.ModifierKeys
        If (mods And System.Windows.Forms.Keys.Control) > 0 Then
            Dim jpao As New JigPromptAngleOptions(vbLf & "Specify the rotation: ")
            jpao.UseBasePoint = True
            jpao.BasePoint = myBRef.Position
            jpao.Cursor = CursorType.Invisible
            jpao.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.UseBasePointElevation)
            Dim pdr As PromptDoubleResult = prompts.AcquireAngle(jpao)
            If _rot = pdr.Value Then
                Return SamplerStatus.NoChange
            Else
                _rot = pdr.Value
                Return SamplerStatus.OK
            End If
        Else
            Dim jppo As New JigPromptPointOptions(vbLf & "Specify insertion point (or press Ctrl for rotation): ")
            jppo.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NullResponseAccepted)
            Dim ppr As PromptPointResult = prompts.AcquirePoint(jppo)
            If _pos.DistanceTo(ppr.Value) < Tolerance.[Global].EqualPoint Then
            Else
                _pos = ppr.Value
            End If
        End If
    End Function
    Protected Overrides Function Update() As Boolean
        myBRef.Position = _pos
        myBRef.Rotation = _rot + _ucsRot
        Return True
    End Function
End Class
One more step further.
Using a class which implements the System.Windows.Forms.IMessageFilter interface allows to catch some key down during the jig drag and perform some changes to the block rotation.
In the following sample, it's used to add 90° to the block current rotation each time the user hits the Tab key.
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace InsertBlockSample
public class CommandMethods
[CommandMethod("Test")]
public void Test()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptResult psr = ed.GetString("\nEnter the block name: ");
if (psr.Status != PromptStatus.OK) return;
string blockName = psr.StringResult;
InsertBlock(blockName);
private void InsertBlock(string blockName)
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
if (bt.Has(blockName))
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[blockName], OpenMode.ForRead);
using (BlockReference br = new BlockReference(Point3d.Origin, bt[blockName]))
br.TransformBy(ed.CurrentUserCoordinateSystem);
BlockTableRecord curspace =
(BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
curspace.AppendEntity(br);
tr.AddNewlyCreatedDBObject(br, true);
BlockJig jig;
if (btr.HasAttributeDefinitions)
Dictionary<string, TextInfo> attInfos = new Dictionary<string, TextInfo>();
RXClass attribClass = RXClass.GetClass(typeof(AttributeDefinition));
foreach (ObjectId id in btr)
if (id.ObjectClass == attribClass)
AttributeDefinition attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
AttributeReference attRef = new AttributeReference();
attRef.SetAttributeFromBlock(attDef, br.BlockTransform);
br.AttributeCollection.AppendAttribute(attRef);
tr.AddNewlyCreatedDBObject(attRef, true);
attInfos.Add(attDef.Tag, new TextInfo(attDef));
jig = new BlockAttribJig(br, attInfos);
else
jig = new BlockJig(br);
TabKeyDownFilter tabFilter = new TabKeyDownFilter(jig);
System.Windows.Forms.Application.AddMessageFilter(tabFilter);
PromptResult pr = ed.Drag(jig);
if (pr.Status != PromptStatus.OK)
br.Erase();
System.Windows.Forms.Application.RemoveMessageFilter(tabFilter);
else
Application.ShowAlertDialog(string.Format("Block '{0}' not found.", blockName));
tr.Commit();
class BlockJig : EntityJig
protected BlockReference br;
protected Point3d pos;
protected double ucsRot;
protected internal double Rotation { get; set; }
public BlockJig(BlockReference br)
: base(br)
this.br = br;
pos = br.Position;
Matrix3d ucsMat = ed.CurrentUserCoordinateSystem;
CoordinateSystem3d ucs = ucsMat.CoordinateSystem3d;
Matrix3d ocsMat = Matrix3d.WorldToPlane(new Plane(Point3d.Origin, ucs.Zaxis));
ucsRot = Vector3d.XAxis.GetAngleTo(ucs.Xaxis.TransformBy(ocsMat), ucs.Zaxis);
this.Rotation = br.Rotation - ucsRot;
protected override SamplerStatus Sampler(JigPrompts prompts)
System.Windows.Forms.Keys mods = System.Windows.Forms.Control.ModifierKeys;
if ((mods & System.Windows.Forms.Keys.Control) > 0)
JigPromptAngleOptions jpao = new JigPromptAngleOptions(
"\nSpecify the rotation (release Ctrl to validate): ");
jpao.UseBasePoint = true;
jpao.BasePoint = br.Position;
jpao.Cursor = CursorType.RubberBand;
UserInputControls.Accept3dCoordinates |
UserInputControls.UseBasePointElevation);
PromptDoubleResult pdr = prompts.AcquireAngle(jpao);
if (this.Rotation == pdr.Value)
return SamplerStatus.NoChange;
else
this.Rotation = pdr.Value;
return SamplerStatus.OK;
else
JigPromptPointOptions jppo = new JigPromptPointOptions(
"\nSpecify the insertion point (or press Ctrl for rotation): ");
(UserInputControls.Accept3dCoordinates |
UserInputControls.NullResponseAccepted);
PromptPointResult ppr = prompts.AcquirePoint(jppo);
if (pos.DistanceTo(ppr.Value) < Tolerance.Global.EqualPoint)
else
pos = ppr.Value;
protected override bool Update()
br.Position = pos;
UpdateRotation();
return true;
internal void UpdateRotation()
br.Rotation = this.Rotation + ucsRot;
class BlockAttribJig : BlockJig
private Dictionary<string, TextInfo> attRefInfos;
private Transaction tr;
public BlockAttribJig(BlockReference br, Dictionary<string, TextInfo> attInfos)
: base(br)
attRefInfos = attInfos;
tr = br.Database.TransactionManager.TopTransaction;
base.Update();
foreach (ObjectId id in br.AttributeCollection)
AttributeReference att = (AttributeReference)tr.GetObject(id, OpenMode.ForWrite);
string tag = att.Tag.ToUpper();
if (attRefInfos.ContainsKey(tag))
TextInfo ti = attRefInfos[tag];
att.Position = ti.Position.TransformBy(br.BlockTransform);
att.Rotation = ti.Rotation + br.Rotation;
if (ti.IsAligned)
att.AlignmentPoint =
ti.Alignment.TransformBy(br.BlockTransform);
att.AdjustAlignment(br.Database);
if (att.IsMTextAttribute)
att.UpdateMTextAttribute();
return true;
struct TextInfo
public readonly Point3d Position, Alignment;
public readonly bool IsAligned;
public readonly double Rotation;
public TextInfo(DBText text)
this.Position = text.Position;
this.Alignment = text.AlignmentPoint;
this.IsAligned = text.Justify != AttachmentPoint.BaseLeft;
this.Rotation = text.Rotation;
class TabKeyDownFilter : System.Windows.Forms.IMessageFilter
private const int WM_KEYDOWN = 0x100;
private BlockJig jig;
public TabKeyDownFilter(BlockJig jig)
this.jig = jig;
public bool PreFilterMessage(ref System.Windows.Forms.Message m)
if (m.Msg == WM_KEYDOWN && (int)m.WParam == 9)
jig.Rotation += Math.PI / 2.0;
jig.UpdateRotation();
return false;
_gile
Message 2 of 13 (183 Views)
Re : Rotate Prior to Insertion of Block
05-02-2014 08:28 AM in reply to: Ron_M
You can add a Rotation property in the BlockJig class so that you can get the specified rotation from the calling method and set this rotation to the inserted BlockReference.
Gilles Chanteau
Valued Contributor
Ron_M
Message 3 of 13 (179 Views)
05-02-2014 08:37 AM in reply to: _gile
I had thought I had done that as I can rotate the block on the cursor prior to selecting the insertion point. I can't seem to get the rotation returned to the inserted block.
_gile
Message 4 of 13 (164 Views)
05-03-2014 05:28 AM in reply to: Ron_M
I didn't read your code enough attentively.
Here's a little sample closer to my understanding of your request (the code don't care about loading the block if not existing in the block table to focus to the  BlockJig).
        public void Test()
                        BlockJig jig = new BlockJig(br);
                        if (pr.Status == PromptStatus.OK)
                else
                tr.Commit();
        protected BlockReference _br;
        protected Point3d _pos;
        protected double _rot, _ucsRot;
            : base(br)
           _br = br;
            _pos = br.Position;
            _ucsRot = Vector3d.XAxis.GetAngleTo(ucs.Xaxis.TransformBy(ocsMat), ucs.Zaxis);
            _rot = br.Rotation - _ucsRot;
                jpao.BasePoint = _br.Position;
                if (_rot == pdr.Value)
                else
                    _rot = pdr.Value;
            else
                if (_pos.DistanceTo(ppr.Value) < Tolerance.Global.EqualPoint)
                else
                    _pos = ppr.Value;
            _br.Position = _pos;
            _br.Rotation = _rot + _ucsRot;
            return true;
Gilles Chanteau
_gile
Message 5 of 13 (153 Views)
05-03-2014 01:40 PM in reply to: _gile
One step further.
If the block have attributes and you want to diplay them during the jig dragging, you may add the block reference and the attribute references before dragging and erase it if ed.Drag(jig) does not return PromptStatus.OK
I use another class (BlockAttribJig) which inherits from BlockJig and only cares of updating the attributes geometry.
I also use a little structure (AttInfo) to store the text informations of the attribute definitions.
        public void Test()
                        BlockJig jig;
                        else
                            br.Erase();
                else
                tr.Commit();
        protected double ucsRot, rot;
            : base(br)
            this.br = br;
            pos = br.Position;
            rot = br.Rotation - ucsRot;
                if (rot == pdr.Value)
                else
                    rot = pdr.Value;
            else
                else
                    pos = ppr.Value;
            br.Position = pos;
            br.Rotation = rot + ucsRot;
            return true;
            : base(br)
            base.Update();
                    if (ti.IsAligned)
            return true;
    struct TextInfo
Gilles Chanteau
_gile
Message 6 of 13 (147 Views)
05-03-2014 02:21 PM in reply to: _gile
using System;
        public void Test()
                        BlockJig jig;
                        else
                            br.Erase();
                else
                tr.Commit();
            : base(br)
            this.br = br;
            pos = br.Position;
                else
            else
                else
                    pos = ppr.Value;
            br.Position = pos;
            UpdateRotation();
            return true;
            : base(br)
            base.Update();
                    if (ti.IsAligned)
            return true;
    struct TextInfo
            this.jig = jig;
            return false;
Gilles Chanteau
Valued Contributor
Ron_M
Message 7 of 13 (124 Views)
05-05-2014 03:31 AM in reply to: _gile
Thanks for all of the input. I'm going to start digesting this morning and will follow up soon.
Valued Contributor
Ron_M
Message 8 of 13 (114 Views)
05-05-2014 03:58 AM in reply to: _gile
And now I know why you are an "Expert Elite".  Many thanks for this.  I'm going to try to get back the modeless library window and multiple insertion on my own.  Had it previously so I don't think that will be difficult.  Again, if I could upgrade your rating I would.
Valued Contributor
Ron_M
Message 9 of 13 (101 Views)
05-05-2014 11:21 AM in reply to: _gile
At this time I am unable to visually see the attributes in the blocks during or after insertion.  I've gone back to a point where I had that working but am so far I have proven inadequate to integrating it into the block insertion with rotate with attInfos.  The attributes are there in the block, the blocks haven't changed in construction, I can attedit the attributes, but I can't see them.  Any ideas?
_gile
Message 10 of 13 (98 Views)
05-05-2014 11:47 AM in reply to: Ron_M
Did you add the block reference and its attributes to the current space and the transaction before dragging the block?
Gilles Chanteau
