.NET
.NET
Active Member
ivo.zagar
Message 1 of 4 (253 Views)
RibbonTab from code crashes Publish command
253 Views, 3 Replies
04-18-2013 08:23 AM
I have a plugin to Exchange store (if the DLL is loaded from ApplicationPlugins folder, ComponentMaćnager.Ribbon does not exist in IExtensionApplication.Initialize() event). This is why I am creating Ribbon from ComponentManager.ItemInitialized event, as described in this postIn the event, I create new Ribbon tab:
            RibbonPanelSource panelSrc = new RibbonPanelSource();
            panelSrc.Name = name;
            panelSrc.Title = title;
            panelSrc.Id = id;
The commands are loaded and everything works fine, but I get error message, when trying to Publish sheet list. Exception information in minidump:
The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
The error does not occur, if I remove the plugin or if I do not create Ribbon from code.
Thanks for any suggestion, cheers.
ADN Support Specialist
fenton.webb
Message 2 of 4 (219 Views)
Re: RibbonTab from code crashes Publish command
04-22-2013 04:01 PM in reply to: ivo.zagar
You can't initialize the Ribbon from Initialize. Check out this link http://adndevblog.typepad.com/autocad/2013/04/autoloader-example-for-invoking-a-startup-command-in-a...
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Distinguished Mentor
BlackBox_
Message 3 of 4 (216 Views)
04-22-2013 04:19 PM in reply to: fenton.webb
Fenton, if I may, the OP is not attempting to add the RibbonTab via Initialize(), he's following Augusto's post to use Initialize() to hook ComponentManager.ItemInitialized event.
Besides, methinks that's the least of the OP's issue, given the seemingly related Publish crash.
Cheers
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
AutoCAD® 2014, and Civil 3D® 2014 Certified Professional ~ Autodesk® Authorized Developer
Valued Mentor
DiningPhilosopher
Message 4 of 4 (210 Views)
04-22-2013 05:28 PM in reply to: ivo.zagar
The ComponentManager's ItemInitialized event is really not an appropriate place to do ribbon initialization, so I'm not sure what the person that wrote that ADN post was thinking, but that's a 'hack' that he obviously hasn't tested.
Can you tell us what BACKGROUNDPLOT is set to?
You can use the class posted in this thread to ensure that your ribbon initialization code runs in the correct execution context:
http://www.theswamp.org/index.php?topic=44440.msg496962#msg496962
