.NET
Ribbon that disappears
6 REPLIES 6
mamj
825 Views, 6 Replies
Hi everybody
I have created a custom ribbon in vb.net. And it works now.
However. To make it work i had to do a workaround because IExtensionApplication.Initialize is apparently run before the Ribbon is created in AutoCAD. To make it work i created a time that runs until the ribbon is created.
But i think this is implementation is flawed since i had to do the workaround, but also because the ribbon disappearse when the ribbon is updated. Say when the user changes something in the CUI menu. I haven't been able to find any solution to this issue on the forum or on the web in general. Does anyone have an idea what i'm doing wrong?
    Partial Public Class BenteMenu
        Implements IExtensionApplication
        Dim WithEvents WSARibPanel As RibbonPanel
        Dim WithEvents ReformerRibPanel As RibbonPanel
        Dim WithEvents CNVPanel As RibbonPanel
        Dim WithEvents ModelPanel As RibbonPanel
        Dim WithEvents LayoutPanel As RibbonPanel
        Private WithEvents ribbonTimer As New Timer()
        Private WithEvents thsdwg As AcadDocument
        Private WithEvents docs As  DocumentCollection
        Public Sub Initialize() Implements IExtensionApplication.Initialize
            If Threading.Thread.CurrentThread.CurrentCulture.ToString <> "en-GB" Then
                Threading.Thread.CurrentThread.CurrentCulture = New CultureInfo("en-GB", False)
            HTEventLog.InitLog("AutoCAD Tools")
            ThisDwg.InitNow()
            docs = Application.DocumentManager
            acadApp = Application.AcadApplication()
            thsdwg = Application.AcadApplication.ActiveDocument
            ThisDrawing = Application.AcadApplication.ActiveDocument
            ribbonTimer.Interval = 2000
            ribbonTimer.Start()
        End Sub
        Public Sub Terminate() Implements IExtensionApplication.Terminate
        End Sub
        Private Function getBmpImage(ByVal imageName As String) As BitmapImage
            Try
                Dim bImg As New BitmapImage(New System.Uri(strIconPath & imageName))
                Return bImg
            Catch
                LogError("Icon Not Found: " & imageName)
            End Try
            Return Nothing
        End Function
        Private Sub CreateLayoutPanel(ByVal BenteTab As RibbonTab)
            If BenteTab Is Nothing Then Return
            Dim ribSourcePanel As New RibbonPanelSource()
            ribSourcePanel.Title = "Paper Bente"
            'now the panel
            LayoutPanel = New RibbonPanel()
            LayoutPanel.Source = ribSourcePanel
            BenteTab.Panels.Add(LayoutPanel)
            ' Creating Contents
            LayoutPanel.IsVisible = My.Settings.PaperBenteVisible
        End Sub
        Private Sub CreateModelPanel(ByVal BenteTab As RibbonTab)
            ribSourcePanel.Title = "Model Bente"
            'now the panel
            ModelPanel = New RibbonPanel()
            ModelPanel.Source = ribSourcePanel
            BenteTab.Panels.Add(ModelPanel)
            ' Creating content
            ModelPanel.IsVisible = My.Settings.ModelBenteVisible
        End Sub
        Private Sub CreateCNVPanel(ByVal BenteTab As RibbonTab)
            ribSourcePanel.Title = "Converter Bente"
            'now the panel
            CNVPanel = New RibbonPanel()
            CNVPanel.Source = ribSourcePanel
            BenteTab.Panels.Add(CNVPanel)
            'Creating Content
            CNVPanel.IsVisible = My.Settings.ConverterBenteVisible
        End Sub
        Private Sub CreateWSAPanel(ByVal BenteTab As RibbonTab)
            ribSourcePanel.Title = "WSA Bente"
            'now the panel
            WSARibPanel = New RibbonPanel()
            WSARibPanel.Source = ribSourcePanel
            BenteTab.Panels.Add(WSARibPanel)
            'creating contents
            WSARibPanel.IsVisible = My.Settings.WSABenteVisible
        End Sub
        Private Sub CreateReformerPanel(ByVal BenteTab As RibbonTab)
            ribSourcePanel.Title = "Reformer Bente"
            'now the panel
            ReformerRibPanel = New RibbonPanel()
            ReformerRibPanel.Source = ribSourcePanel
            BenteTab.Panels.Add(ReformerRibPanel)
            'Creating contents
            ReformerRibPanel.IsVisible = My.Settings.ReformerBenteVisible
        End Sub
        Private Function CreateButton(ByVal text As String, ByVal CommandParameter As String, ByVal showtext As Boolean, ByVal showImage As Boolean, ByVal smallImage As BitmapImage, ByVal largeImage As BitmapImage, ByVal orientation As System.Windows.Controls.Orientation, ByVal size As Autodesk.Windows.RibbonItemSize)
            Try
                Dim ribbonbutton1 As New RibbonButton()
                ribbonbutton1.Text = text
                ribbonbutton1.CommandParameter = CommandParameter
                ribbonbutton1.ShowText = showtext
                ribbonbutton1.ShowImage = showImage
                If showImage Then
                    If size = RibbonItemSize.Standard Then
                        If Not smallImage Is Nothing Then ribbonbutton1.Image = smallImage
                    Else
                        If Not largeImage Is Nothing Then ribbonbutton1.LargeImage = largeImage
                ribbonbutton1.Orientation = orientation
                ribbonbutton1.Size = size
                ribbonbutton1.CommandHandler = New AdskCommandHandler()
                Return ribbonbutton1
            Catch ex As System.Exception
                LogError(text & " Button failed", ex)
                Return Nothing
            End Try
        End Function
        Private Sub CreateRibbon() Handles ribbonTimer.Tick
            Dim ribCntrl As RibbonControl
            Dim BenteTab As RibbonTab = Nothing
            ribCntrl = ComponentManager.Ribbon
            If ribCntrl Is Nothing Then Return
            SendMessage("Creating Bente")
            ribbonTimer.Stop()
            ribbonTimer = Nothing
                For i As Integer = 0 To ribCntrl.Tabs.Count - 1
                    If ribCntrl.Tabs(i).Title = "Bente 2.0" Then
                        BenteTab = ribCntrl.Tabs(i)
                Next
            Else
                If Not ribCntrl.Tabs.Contains(BenteTab) Then
                    ribCntrl.Tabs.Insert(3, BenteTab)
            'add the tab
                BenteTab = New RibbonTab()
                BenteTab.Title = "Bente 2.0"
                BenteTab.Id = "BenteTab"
            If BenteTab.Panels.Count = 0 Then
                CreateLayoutPanel(BenteTab)
                CreateModelPanel(BenteTab)
                CreateWSAPanel(BenteTab)
                CreateCNVPanel(BenteTab)
                CreateReformerPanel(BenteTab)
        End Sub
Best regards Magnus
6 REPLIES 6
Irvin
in reply to: mamj
Hi magnus,
I know for a fact when u user changes his workspace the ribbon wil disapear. I think when a user changes his cui file the same principle goes.
Please look at this example this handles the ribbon load IExtensionApllication and  when a user changes his workspace.
http://forums.autodesk.com/t5/NET/RibbonTab-in-all-Workspaces/td-p/2853958
Kind regards,
Irvin
mamj
in reply to: Irvin
Hi Irvin
It doesn't work when you change something in the CUI menu. Otherwise it works fine. Have you had this experience?
br Magnus
Irvin
in reply to: mamj
Hi there ik think you should reload your ribbon like in the example only now ik think you should use the commandended event.
pseudo code:
if(command cui) ended
reload ribbon
I dont know if there is a AutoCAD variable wich can indicate if the cui file has changed. But i think you should look at the commandended event.
Kind regards
Irvin
mamj
in reply to: Irvin
Hi Irvin
This strikes me as a poor solution since listening to the CommandEnded event would have my program triggered everytime a command is ended, making my program slow down AutoCAD.
Is there really no official solution from Autodesk to this problem?
br Magnus
Tags (3)
Irvin
in reply to: mamj
I don't think it's a poor solution. For that mater you also use en event that checks a variable has changed. In this case when the user changes it workspace. Your ribbon wil be reloaded.
Of you look ad event's autodesk does not recommend to use transactionhandling within events. So you use the commandended event to do that kind of work.
I don't think this wil have much impact on performance. Because you only need to check
if (commandended != cui) return;
I don't have an other solution for you.
I use commandended alot but have no performance issues.
irvin
mamj
in reply to: mamj
ok.. I will try it then.
”Boost
