.NET
Ribbon : Large image text on two lines.
2 REPLIES 2
quigs
494 Views, 2 Replies
Hi there,
I am creating a ribbon using the ribbon .api from examples I have found here.
I am trying to get the labels for the large icons to appear on 2 lines (right) but i'm
having no luck.  Any ideas?
Thank you,
Martin.
My name is Martin.. 😄
2 REPLIES 2
fieldguy
in reply to: quigs
What have you tried so far?  This works for form labels.
Dim lstatelabel As String = "Current Layer State:" & ControlChars.NewLine & "Path: "
quigs
in reply to: fieldguy
That worked great, thank you :D.
”Boost
