.NET
Ribbon button size too big
3 REPLIES 3
khunstad
836 Views, 3 Replies
Hi!
I have programmed a ribbbon with .NET. I want the buttons to show only a large bitmap with no text under. I specify:
RibbonButton button = new RibbonButton();
button.Orientation = Orientation.Vertical;
button.Size = RibbonItemSize.Large;
button.ShowText = false;
button.ShowImage = true;
button.Id = buttonId;
and set the image. The problem is that when I hover the mouse over the button, it is clear that the system is holding up vertical space for a text below. When I want 2 rows of such icons, there is a lot of free space and the ribbon gets much higher than necessary.
What setting rules this, when it is not enough to set ShowImage to false?
3 REPLIES 3
philippe.leefsma
in reply to: khunstad
Simply try Orientation.Horizontal.
It seems that it doesn't hold space this way...
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
khunstad
in reply to: philippe.leefsma
Thought I had tried that at some point, but I changed it in the wrong place and it got overridden. So now I checked more thoroughly and everything looks great!
Thank you!
philippe.leefsma
Cheers 😉
Philippe Leefsma
”Boost
