Solved by LE3. Go to Solution.
I too am interested in this. But a lack of response for the past few months doesn't bode well...
Not sure I have not messed with it but the revision cloud is nothing but a polyline. It uses that last used arc length stored in the registeriy but I did see any system variables given for that.
So maybe you start thinking of creating a polyline with arcs
Got a reply from Dev Help on this subject and they said the same thing.
Here is some sample code for anyone else who needs it:
[CommandMethod("addPline")]
public static void addPline()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction Tx = db.TransactionManager.StartTransaction())
BlockTable table = Tx.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord model = Tx.GetObject(table[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
Polyline polyline = new Polyline();
polyline.SetDatabaseDefaults();
double angleDeg = 180.0;
//Converts angle to radians and then compute bulge. (Nb. Atan(1) = Pi/4)
double bulge = Math.Tan(angleDeg * Math.Atan(1) / 180.0);
polyline.AddVertexAt(polyline.NumberOfVertices, new Point2d(0, 0), bulge, 0, 0);
polyline.AddVertexAt(polyline.NumberOfVertices, new Point2d(10, 10), -bulge, 0, 0);
polyline.AddVertexAt(polyline.NumberOfVertices, new Point2d(20, 20), bulge, 0, 0);
polyline.AddVertexAt(polyline.NumberOfVertices, new Point2d(30, 30), -bulge, 0, 0);
model.AppendEntity(polyline);
Tx.AddNewlyCreatedDBObject(polyline, true);
Tx.Commit();
Hi Chris,
Wow that's what they provide... hmmm
Anyway, here is a modified version of a jig sample provided by Kean W. in his web site http://through-the-interface.typepad.com
Notes:
- it does not closed automatically (just press enter to stop and do that when getting closer to the starting point, the arcs are drawn based on the point selection)
See if helps, have fun!
#region Revision Cloud - Simple
class RevCloudJig : EntityJig
// Use a separate variable for the most recent point...
// Again, not strictly necessary, but easier to reference
Point3d m_tempPoint;
Plane m_plane;
bool m_isArcSeg = false;
bool m_isUndoing = false;
// At this stage, our arc segments will
// have a fixed bulge of 1.0...
// Later we may update the routine to determine
// the bulge based on the relative location
// of the cursor
const double kBulge = 1.0;
public RevCloudJig(Matrix3d ucs) : base(new Polyline())
// Create a temporary plane, to help with calcs
Point3d origin = new Point3d(0, 0, 0);
Vector3d normal = new Vector3d(0, 0, 1);
normal = normal.TransformBy(ucs);
m_plane = new Plane(origin, normal);
// Create polyline, set defaults, add dummy vertex
Polyline pline = Entity as Polyline;
pline.SetDatabaseDefaults();
pline.Normal = normal;
AddDummyVertex();
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptPointOptions jigOpts = new JigPromptPointOptions();
jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates |
UserInputControls.NullResponseAccepted | UserInputControls.NoNegativeResponseAccepted);
m_isArcSeg = true;
if (pline.NumberOfVertices == 1)
// For the first vertex, just ask for the point
jigOpts.Message = "\nStart point of revision: ";
else if (pline.NumberOfVertices > 1)
jigOpts.SetMessageAndKeywords("\nSpecify next point or [Undo]: ", "Undo");
// For subsequent vertices, use a base point
//if (m_isArcSeg)
// jigOpts.SetMessageAndKeywords("\nSpecify endpoint of arc or [Line/Undo]: ", "Line Undo");
//else
//jigOpts.SetMessageAndKeywords("\nSpecify next point or [Arc/Undo]: ", "Arc Undo");
else // should never happen
return SamplerStatus.Cancel;
// Get the point itself
PromptPointResult res = prompts.AcquirePoint(jigOpts);
if (res.Status == PromptStatus.Keyword)
if (res.StringResult == "Arc")
m_isArcSeg = true;
//else if (res.StringResult == "Line")
// m_isArcSeg = false;
else if (res.StringResult == "Undo")
m_isUndoing = true;
return SamplerStatus.OK;
else if (res.Status == PromptStatus.OK)
// Check if it has changed or not
// (reduces flicker)
if (m_tempPoint == res.Value)
return SamplerStatus.NoChange;
else
m_tempPoint = res.Value;
protected override bool Update()
// Update the dummy vertex to be our
// 3D point projected onto our plane
pline.SetPointAt(pline.NumberOfVertices - 1, m_tempPoint.Convert2d(m_plane));
// If it's supposed to be an arc segment,
// set the bulge appropriately
if (m_isArcSeg)
pline.SetBulgeAt(pline.NumberOfVertices - 1, kBulge);
//else // Otherwise, it's a line, so set the bulge to zero
// pline.SetBulgeAt(pline.NumberOfVertices - 1, 0);
return true;
public Entity GetEntity()
return Entity;
public bool IsArcSegment()
return m_isArcSeg;
public bool IsUndoing()
return m_isUndoing;
public void AddDummyVertex()
// Create a new dummy vertex...
// can have any initial value
pline.AddVertexAt(pline.NumberOfVertices, new Point2d(0, 0), 0, 0, 0);
public void RemoveDummyVertex()
// Let's first remove our dummy vertex
if (pline.NumberOfVertices > 0)
pline.RemoveVertexAt(pline.NumberOfVertices - 1);
// And then check the type of the last segment
if (pline.NumberOfVertices >= 2)
double blg = pline.GetBulgeAt(pline.NumberOfVertices - 2);
m_isArcSeg = (blg != 0);
public void AdjustSegmentType(bool isArc)
// Change the bulge of the previous segment,
// if necessary
double bulge = 0.0;
if (isArc)
bulge = kBulge;
pline.SetBulgeAt(pline.NumberOfVertices - 2, bulge);
[CommandMethod("MYREVCLOUD")]
public void cmd_revcloudJig()
// Get the current UCS, to pass to the Jig
Matrix3d ucs = ed.CurrentUserCoordinateSystem;
// Create our Jig object
RevCloudJig jig = new RevCloudJig(ucs);
// Loop to set the vertices directly on the polyline
bool bPoint = false;
bool bKeyword = false;
bool bComplete = false;
do
PromptResult res = ed.Drag(jig);
bPoint = (res.Status == PromptStatus.OK);
// A new point was added
if (bPoint) jig.AddDummyVertex();
bKeyword = (res.Status == PromptStatus.Keyword);
if (bKeyword)
if (jig.IsUndoing())
jig.RemoveDummyVertex();
else
jig.AdjustSegmentType(jig.IsArcSegment());
// Null input terminates the command
bComplete = (res.Status == PromptStatus.None);
if (bComplete)
// Let's clean-up the polyline before adding it
} while ((bPoint || bKeyword) && !bComplete);
// If the jig completed successfully,
// add the polyline
if (bComplete)
Polyline pline = jig.GetEntity() as Polyline;
// Append entity
Transaction tr = db.TransactionManager.StartTransaction();
using (tr)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead, false);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
btr.AppendEntity(pline);
tr.AddNewlyCreatedDBObject(pline, true);
tr.Commit();
#endregion
Hi Luis!
Yes, that is all they returned in their reply... Not an unusual reply for Dev Help. I'll try your code. You always give out good help.
HI all thanks for the responses! I had completely abandoned this thread until I randomly came back upon it. Luis I did try doing some code very similar to your response based on the same Kean blog post. My code had the same issues though. You still have to click the mouse to add each Vertex point which of course in a regular revision cloud you don't, plus flickering starts as your polyline starts to have several vertexes and the jig has to redraw the entire polyline.
Of course some method of determining mouse coordinate from last vertex and adding a vertex to the polyline without user clicking would be nessessary. Also as mentioned before the regular AutoCAD revision cloud appears to "commit" the polyline up to the last vertex, and when a new vertex is entered it probably updates or replaces the polyline with the added vertex. This way you don't have the massive flickering as the jig doesn't have to redraw the entire polyline.
Anyone know how to get user mouse coordinates without the user clicking in a jig? That would really help and I could try things from there. It would really be awesome if Kean did a blog post on this subject. How does one send him request for such things?
Got the chance to port the autolisp code, idea and concept by David Harrington to C# - Did just the basic, does not include all (change the arc length or save the value for next use), but the command works as in the early days.
Anyone can add any missing features, attached it is the full source code file.
Provided as-is.
HTH.
Sample:
// Based on the original Code, idea and concept by David Harrington
// Code ported to C# by LE OCT.24.2010.
namespace RevCloudNET
public class RevCloudCommand
// ARX: int acedGrRead(int track, int * type, struct resbuf * result);
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode)]
public extern static int acedGrRead(int track, out int display, IntPtr result);
// ARX: int acedCmd(const struct resbuf * rbp);
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl)]
extern static int acedCmd(IntPtr rbp);
const int RTNORM = 5100;
const int RTCAN = -5002;
const short RTSTR = 5005;
const int RT3DPOINT = 5009;
const int RTREAL = 5001;
public static void drawCloud()
if (AcadApp.DocumentManager.IsApplicationContext) return;
Database db = HostApplicationServices.WorkingDatabase;
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
int status = 0;
double incAngle = 110.0;
double arcDist = 0.0;
if (Convert.ToInt32(AcadApp.GetSystemVariable("DIMSCALE")) == 0)
arcDist = 0.375;
else
arcDist = 0.375 * Convert.ToInt32(AcadApp.GetSystemVariable("DIMSCALE"));
PromptPointResult res = ed.GetPoint("\nPick cloud start point: ");
if (res.Status != PromptStatus.OK) return;
Thanks Luis for the code! Part of the revision cloud routine I am trying to do is once a revision cloud is finished the user then inserts a block reference. I found that if the user cancels the revision cloud the code still wants 2 more escape presses before it completely exits out of the Revision cloud. Unfortunatly when the user tries to insert the block reference Autocad then throws an unhandled exception. I tried several things to try and not get the this to happen, Nothing has been successful so far. I'll post if I come up with anything. I really wish Kean would do this in his blog.
I've got a temporary solution and that is to have the user insert the block reference first then do the cloud. Of course that is the solution I had before but that is not what everyone is used to in the old lisp routine we had and they already pitched a fit about that. Some people just despise change.
