.NET
Return the coordinates of a LWPOLYLINE
3 REPLIES 3
657 Views, 3 Replies
I realize this is probably a VB.NET 101 question, but it's been a couple days and I'm getting frustrated.
I want to get a collection of the Point3D values (coordinates) of a LWPOLYLINE (open or closed), that's it. For example, while in AutoCAD, if I use the LIST command on my polyline, I get the following results;
at point X= 100'-0" Y= 100'-0" Z= 0'-0"
at point X= 110'-0" Y= 100'-0" Z= 0'-0"
at point X= 110'-0" Y= 105'-0" Z= 0'-0"
at point X= 105'-0" Y= 105'-0" Z= 0'-0"
at point X= 105'-0" Y= 110'-0" Z= 0'-0"
at point X= 100'-0" Y= 110'-0" Z= 0'-0"
I need my sub to give me the coordinates shown above, but cannot find a way to do it. I'm aware of Polyline.GeometryExtents and Polyline.Bounds, but all that does is give me the coordinates of the opposite corners, and doesn't account for the fact a rectangle may be rotated.
Any help is very appreciated.
Thanks in advance,
George
3 REPLIES 3
norman.yuan
Look at Polyline.NumberOfVertices property and Polyline.GetPoint3dAt() method.
Assume you have already obtained a valid Polyline object, represented with variable "pline":
Dim pts As New List(of Point3d)()
For i As Integer=0 To pline.NumberOfVertices
 pts.Add(pline.GetPoint3dAt(i)
Next
Norman Yuan
Drive CAD With Code
For I as Integer = 0 to pline.NumberOfVertices - 1
Details are tiny daggers 😉
in reply to: norman.yuan
Thank you so much norman.yuan & cheifbraincloud, was exactly what I needed.I clicked both responses as the 'accepted solution'.
I thought it would be something simple, and of course, it was, I just couldn't find the solution here or at theswamp.org.
George
”Boost
