.NET
Return an AssocVariable By Name
2 REPLIES 2
BellwetherBill
566 Views, 2 Replies
Is there a way to get an AssocVarible by specifying the name of the variable rather than iterating through all the Actions returned by the AssocNetwork.GetActions property?
2 REPLIES 2
So let me rephrase my question. I am trying to figure out a way to access AssocVariables within blocks along with the top level of the ACAD_ASSOCNETWORK without selecting the entities on screen.
I can see the AcDbAssocNetwork objects that I want in the namedobjects dictionary using the ArxDebug tool and I can get to the AssocVariables but using the AssocNetwork.GetInstancesFromObject(Symbolutil(db),true,true,"") only seams to give me access to the top level AssocVariables and not the variables associated with blocks and nested inside AssocArrays.
Does anyone have any ideas?
I have attached some test code as a text file so it's easier to read. I'm not sure if the ultimate implementation will work the way I want but this is what I have so far.
I would appreciate any feedback.
”Boost
