.NET
Retrieve SaveAs version in Database.BeginSave
2 REPLIES 2
meichtf
517 Views, 2 Replies
Is there a way to retrieve the fileversion in the Database.BeginSave event when the user has choosen like version 2004 in the default SAVEAS command?
I only found the OriginalFileVersion and LastSaveAsVersion property, however I have to add something in the database for version 2004 before it is saved. Or is there another approach?
Thank you
2 REPLIES 2
arcticad
in reply to: meichtf
The Data is stored in the registry
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8001:409\Profiles\Initial Setup Profile\General
DefaultFormatForSave
value 30 for 2010
value 24 for 2007
value 18 for 2004
This might help depending on what your doing. it will check the
file and see which version it's currently saved as.
History of the version numbers is found here
http://en.wikipedia.org/wiki/.dwg
   Function is2010(ByVal filename As String) As Boolean
        'Return False
        'Exit Function
        Dim rtnCheck As Boolean = False
        Dim objReader As IO.StreamReader
        Dim txtContents As String
        ' Check if File Exists
        If IO.File.Exists(filename) Then
            objReader = IO.File.OpenText(filename)
            'Read all the Text in the File
            Do While objReader.Peek <> -1
                txtContents = objReader.ReadLine()
                If txtContents.Substring(0, 6) = "AC1024" Then
                    rtnCheck = True
                End If
                Exit Do
            Loop
            ' Don't forget to close the file
            objReader.Close()
            objReader = Nothing
        End If
        Return rtnCheck
    End Function
(defun botsbuildbots() (botsbuildbots))
meichtf
in reply to: arcticad
Thanks for the answer but this is not quite what I'm looking for. However I would have found a solution in c++ : There is a method in the AcApDocument class:
virtual SaveFormat formatForSave() const = 0;
Is there a .NET property or method anywhere that I could query in the Document.BeginSave event?
”Boost
