.NET
Retrieve block
0 REPLIES 0
Message 1 of 1
113 Views, 0 Replies
Retrieve block
I have referenced the acdbmgd.dll and acmgd.dll in VB.NET as I read in the posts here, that this will work with later versions of AutoCAD and that is my whole intention too. But when I use this method, I cannot get the 'bind' property to bind blocks in a drawing that is kept opened. This is possible by referencing the AutoCAD Type Library and using the conventional method of GetObject(, "Autocad.Application.16.2"). Why is it so? Is there any way that I can create this app and use it even for later versions.
Please help!
0 REPLIES 0
”Boost
