.NET
Blarran
Message 1 of 2 (86 Views)
ResultBuffer and Application.Invoke
86 Views, 1 Replies
08-13-2014 12:44 PM
I'm trying to understand how to send commands using ResultBuffer and Application.Invoke.
I want to be able to jump (or surf) to a component in Autocad Electrical from another application that has a DataGridView. When user clicks on a row, AE jumps to the location of the component in question.
I wrote test code to figure out how to use the ResultBuffer and Application.Invoke. I couldn't get it to work. The work around is to send the commands using SendStringToExecute().
Can someone tell me what I'm doing wrong with setting up the ResultBuffer?
Thanks.
[CommandMethod("TestJump", CommandFlags.Session )]
static public void TestJump()
	string path = @"C:\WORK\AUTOCAD ELECTRICAL\SAMPLE PROJECT\33729802004.DWG";
	path = path.Replace(@"\",@"/");
	// JumpTo(path, "7366"); <<<< DOESN"T WORK
	JumpTo2(path, "7366");
// DOES NOT WORK
public static void JumpTo(string path,string hdl )
	try
		// WHAT IS WRONG???
		ResultBuffer pa = new ResultBuffer();
		pa.Add(new TypedValue(LispUtil.RTSTR, "c:ace_surf_zoom_in_no_dlg"));
		pa.Add(new TypedValue(LispUtil.RTSTR, path));
		pa.Add(new TypedValue(LispUtil.RTSTR, hdl));
		pa.Add(new TypedValue(LispUtil.RTNIL));
		ResultBuffer rb = Application.Invoke(pa);
		Debug.Print(rb.ToString());
	catch (System.Exception ex)
		Debug.Print(ex.Message);
// THIS WORKS
public static void JumpTo2(string path, string hdl)
	string cmd = "(c:ace_surf_zoom_in_no_dlg \"{0}\" \"{1}\" nil) ";
	cmd = string.Format(cmd, path, hdl);
	var doc = Application.DocumentManager.MdiActiveDocument;
	Application.
	doc.SendStringToExecute(cmd, true, false, true);
	doc = null;
ADN Support Specialist
augusto.goncalves
Message 2 of 2 (41 Views)
Re: ResultBuffer and Application.Invoke
08-27-2014 01:35 PM in reply to: Blarran
I'm not sure about the type numbers you're using, but I replaced them with the number and seems to work fine:
public static void JumpTo(string path, string hdl)
  try
    pa.Add(new TypedValue(5005, "c:ace_surf_zoom_in_no_dlg"));
    pa.Add(new TypedValue(5005, path));
    pa.Add(new TypedValue(5005, hdl));
    pa.Add(new TypedValue(5019));
Augusto Goncalves
Autodesk Developer Network
