I know how to change the path of an existing Raster Image by creating a RasterImageDef wrapper and modify SourceFileName property. It works fine, but the actual image name, which I believe is tied to Dictionary entry key, does not change.
So after re-path, if you look into "File References" palette, you will see the old image name with new path.
How can I change the image name after changing the path?
BTW, I'm working with Acad2007
A
