.NET
Active Member
0 Kudos
Post 1 of 4
Replace Block Record
362 Views, 3 Replies
08-06-2012 06:50 AM
Hi all! I look for answers on my question 'How I can replace or redefine block record?'.
I tried the following:
1. Get all the block references
2. Clone it
3. Save to new DateBase
4. Erase old Block REferences and Block Record
5. Copy block references from new DataBase
But it doesn't work. Do you have any ideas?
P.S. If you wаnt, then I can write some code
You're doing a lot of unneccessary work there, with the copying back and forth to a new database.  I have a working routine that goes like this.
1. Open the old BlockTableRecord
2. Get the BlockReferenceIds from the BTR
3. Rename the old BTR (I assume you want the new block to have the same name, or this isn't neccessary)
4. Create the new BlockTableRecord.
5. Loop through the BlockReferenceIds and point the BlockTableRecord property to the new ID, and check for attribute aditions or removals.
Distinguished Mentor
91 Kudos
Post 2 of 4
Re: Replace Block Record
08-06-2012 10:26 AM in reply to: EfremenkoDO
What do You mean with "But it doesn't work"?, you have a workflow with 5 steps, in which one the program fails?, and yes, please post the relevant code.
Gaston Nunez
54 Kudos
Post 3 of 4
08-06-2012 12:28 PM in reply to: EfremenkoDO
Active Member
0 Kudos
Post 4 of 4
08-06-2012 11:03 PM in reply to: chiefbraincloud
Thank you!
