.NET
.NET
Distinguished Contributor
1 Kudo
Post 1 of 10
Replace all 3D Polylines with Cylinders
871 Views, 9 Replies
02-21-2013 01:41 PM
Hey Everyone,
I'm trying to automate a simple yet massively tedious task at the moment. Certain layers of my drawings contain 3D Polylines that have to be converted to cylinders. What I need to do is select all 3D Polylines in a specific layer and automatically convert them to cylinders, these cylinders will all share the same hardcoded diameter, however will retain the x,y,z, positioning of the 3D Polylines. The way that I'm approaching i'm attempting right now is to use a selection filter to select all 3D Polylines, save their co-ordinates into an array, create the cylinders using these co-ordinates and then deleting the existing polylines. At this point though, i'm wondering if there is an easier way to do this or if anybody has solved a similar problem, any input or examples would be greatly appreciated. I'm sure I could pull it off using the approach i've described above, i'm just hoping there's a more efficient way.
Thanks!
Vince, try this one just for first two points of 3dpolyline
extend code to your needs, just a note created cylinders aren't
real cylinder, many properties of them not applicable,
see properties window after creating things
 [CommandMethod("3cy")]
public void Pline3dToExtrudedCylinders()
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
// radius of cylinder
double rad = 10.0;
SelectionFilter filt = new SelectionFilter(new TypedValue[]{
new TypedValue(0,"polyline")});// add: ,new TypedValue(8,"mylayer")
PromptSelectionResult res = ed.GetSelection(filt);
if (res.Status != PromptStatus.OK) return;
SelectionSet sset = res.Value;
Entity ent;
using (Transaction tr = doc.TransactionManager.StartTransaction())
BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
foreach (SelectedObject obj in sset)
ent = tr.GetObject(obj.ObjectId, OpenMode.ForRead) as Entity;
if (ent == null)
return;
Polyline3d poly = ent as Polyline3d;
if (poly == null) return;
Point3d p1= poly.GetPointAtParameter(poly.StartParam);
Point3d p2 = poly.GetPointAtParameter(poly.StartParam+1.0);
Vector3d vec = (p2 - p1).GetNormal();
double height = p1.DistanceTo(p2);
Circle circ = new Circle(p1, vec, rad);
circ.Normal = vec;
ObjectId objId = btr.AppendEntity(circ);
tr.AddNewlyCreatedDBObject(circ, true);
// Get the boundary curves to create a region
DBObjectCollection regs = new DBObjectCollection();
regs.Add(circ);
// Create a region from the circle.
DBObjectCollection regions = new DBObjectCollection();
regions = Region.CreateFromCurves(regs);
if (regions.Count == 0)
ed.WriteMessage("\nFailed to create region\n");
return;
Region reg = (Region)regions[0];
// Extrude the region to create a solid.
Solid3d sol = new Solid3d();
sol.RecordHistory = true;// optional
sol.ShowHistory = false;// optional
sol.Extrude(reg, height, 0.0);
ObjectId solId = ObjectId.Null;
solId = btr.AppendEntity(sol);
tr.AddNewlyCreatedDBObject(sol, true);
if (!circ.IsWriteEnabled) circ.UpgradeOpen();
circ.Erase();
tr.Commit();
171 Kudos
Post 2 of 10
Re: Replace all 3D Polylines with Cylinders
02-22-2013 02:56 AM in reply to: vince1327
            double rad = 10.0;
            Entity ent;
                if (ent == null)
                    return;
                circ.Normal = vec;
                regs.Add(circ);
                    return;
                circ.Erase();
                tr.Commit();
1 Kudo
Post 3 of 10
02-22-2013 05:44 AM in reply to: Hallex
Hey Hallex,
This is just what I was looking for, thank you. I've run into a problem when I run the code on a 3d polyline with multiple segements though. If my 3dpoly is made up of two segements at a 90 degree angle of each other, then the code only convert a single one of those segements to a 3dsolid, is there an easy way to cycle through all of the 3dpoly segements?
1 Kudo
Post 4 of 10
02-22-2013 06:17 AM in reply to: vince1327
Hey Hallex,
Ignore that last post, I realized what is happening, it's that the code is set to grab Point1 and Point2 of the selected 3dpolylines, and if there are more than 2 points to the selected 3dpolyline, it is unable to process them. Is there a command in AutoCAD where I can break a 3dpolyine into it's indivdual segements or an simple way to cycle through the individual segements of a multi-segement polyline in code?
Thanks Again
171 Kudos
Post 5 of 10
02-22-2013 10:14 AM in reply to: vince1327
Hi Vince, sorry, been busy
//Just replace this line:
//with this one:
sol.ExtrudeAlongPath(reg, poly as Curve, 0.0);
1 Kudo
Post 6 of 10
02-25-2013 05:43 AM in reply to: vince1327
Perfect! Thanks Hallex!
171 Kudos
Post 7 of 10
02-25-2013 09:47 PM in reply to: vince1327
Glad to help
Happy coding
Cheers :smileyhappy:
1 Kudo
Post 8 of 10
03-01-2013 06:41 AM in reply to: Hallex
Deleted that last post, had a few issues in 2013 but just figured it out, thanks again!
jso
Member
0 Kudos
Post 9 of 10
04-11-2013 09:29 AM in reply to: vince1327
I think this is exaclty what I am looking for, however I do not know how to run this.  is this a script or lisp?
1 Kudo
Post 10 of 10
04-11-2013 10:26 AM in reply to: vince1327
Hey jso,
This is C# code that must be compiled and run in AutoCAD as a DLL. I use Visual Studio 2010 and AutoCAD 2013 to accomplish this. Hopefully that clears things up a bit.
Cheers
Vince
