.NET
Valued Mentor
KerryBrown
Message 31 of 36 (302 Views)
Re: Repeatedly Insert Block
01-30-2012 11:59 AM in reply to: vince1327
>> The first one is that in the sample code there are references to "CreateLayer", "InsertBlockReference" and "RadiansToDegrees" which don't exist. Are these placeholders for code or are these documented fuctions in the API i can't seem to find? <<
Have a look at Reply #28
http://www.theswamp.org/index.php?topic=37686.msg427833#msg427833
OR
make the .NET forum current
and do a search for the keyword you want
Regards
class keyThumper<T> : Lazy<T>;      another  Swamper
Distinguished Contributor
vince1327
Message 32 of 36 (299 Views)
01-30-2012 12:56 PM in reply to: KerryBrown
When i try to put the code together from reply 28, i get the errors i posted above. When i try the compiled dll that was attached to the post and run BI_20, i get an eFilerError which halts everything. It's making me crazy that what i'm trying to do should be so simple yet is so annoyingly difficult. I've also gone through the .NET forums with no luck on this. I'll keep tacking at it and post any progress.
Cheers
Vince
Valued Mentor
jeff
Message 33 of 36 (284 Views)
01-31-2012 05:35 AM in reply to: vince1327
Maybe try one thing at a time.
1. Can you manually or through the UI insert a block into a drawing?(I guess you are inserting a drawing as block vs a block from another drawing)
2. Can you code just the part to insert another blockreference with attributes?
You can also find your answers @ TheSwamp
vince1327
Message 34 of 36 (278 Views)
01-31-2012 05:51 AM in reply to: jeff
Hey Jeff,
1.) I can insert the block with no problems manually by going to "Insert"-->"Block" from the AutoCAD 2012 GUI.
2.) I'm not sure what you mean here....i need it to be able to insert the block reference with the original attributes and then do that "x' times over. I've tried pre-exploding/bursting the original block in the original dwg but to no avail.
Valued Mentor
gasty1001
Message 35 of 36 (254 Views)
02-02-2012 12:35 PM in reply to: vince1327
Try this:
Private Sub InsertAttibuteInBlockRef(ByVal blkRef As BlockReference, ByVal attributeTag As String, ByVal attributeText As String, ByVal tr As Transaction)
        Dim btr As BlockTableRecord = DirectCast(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
        For Each attId As ObjectId In btr
            Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
            If TypeOf ent Is AttributeDefinition Then
                Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                Dim attRef As New AttributeReference()
                attRef.SetAttributeFromBlock(attDef, blkRef.BlockTransform)
                If attRef.Tag = attributeTag Then
                    attRef.TextString = attributeText
                    Dim id As ObjectId = blkRef.AttributeCollection.AppendAttribute(attRef)
                    tr.AddNewlyCreatedDBObject(attRef, True)
                    Exit For
        Next
    End Sub
Public Sub BlkInsert(ByVal basePath As String, ByVal blkName As String, ByVal px As Point3d, ByVal theta As Double, ByVal sx As Double, ByVal Layer As String, ByVal side As String, ByVal AttValList As ArrayList, ByVal AttTagList As ArrayList)
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database
        acCurDb = HostApplicationServices.WorkingDatabase()
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            If acBlkTbl.Has(blkName) Then
                Dim blkObjId = acBlkTbl(blkName)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Dim blkRef As BlockReference = New BlockReference(px, blkObjId)
                blkRef.Rotation = theta
                blkRef.ScaleFactors = New Scale3d(sx, sx, 1)
                blkRef.Layer = Layer
                acBlkTblRec.AppendEntity(blkRef)
                acTrans.AddNewlyCreatedDBObject(blkRef, True)
                Dim dPropsCollection As DynamicBlockReferencePropertyCollection
                dPropsCollection = blkRef.DynamicBlockReferencePropertyCollection
                For Each dprop As DynamicBlockReferenceProperty In dPropsCollection
                    If dprop.PropertyName = "Visibility1" Then
                        dprop.Value = side
                Next
                Try
                    Dim i As Integer = 0
                    For Each tag As String In AttTagList
                        InsertAttibuteInBlockRef(blkRef, tag, AttValList(i).ToString, acTrans)
                        i = i + 1
                    Next
                    acBlkTblRec.UpdateAnonymousBlocks()
                    blkRef.RecordGraphicsModified(True)
                Catch ex As Exception
                    MsgBox(ex.Message)
                End Try
            Else
                Dim blkFile As String = basePath + "\\" + blkName + ".dwg"
                Dim blkObjId As ObjectId
                Dim dbDwg As New Database(False, True)
                dbDwg.ReadDwgFile(blkFile, IO.FileShare.Read, True, "")
                blkObjId = acCurDb.Insert(blkName, dbDwg, True)
                dbDwg.Dispose()
                        dprop.Value = side
                Next
                    i = i + 1
                Next
            acTrans.Commit()
        End Using
    End Sub
<CommandMethod("MBLKTEST")> _
    Public Sub Blktest()
        Dim TagList As New ArrayList
        Dim ValList As New ArrayList
        Dim side As String = "Top"
        TagList.Add("TAG1")
        TagList.Add("TAG2")
        ValList.Add("VAL1")
        ValList.Add("VAL2")
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim acCurDb As Database = acDoc.Database
        Dim pr As PromptPointResult = ed.GetPoint("Pick a point:")
        If pr.Status = PromptStatus.OK Then
            Dim n As Integer = 10
            Dim basePath As String = "C:\\MyBasePath"
            Dim px As Point3d = pr.Value
            For i = 0 To n
                AlInsert(basePath, "MyBlockName", px, 0, 1, "0", side, ValList, TagList)
                px = Polar(px, 3500, 0)
            Next
    End Sub
Private Function Polar(ByVal bpoint As Point3d, ByVal r As Double, ByVal theta As Double) As Point3d
        Dim px As New Point3d(bpoint.X + r * Math.Cos(theta), bpoint.Y + r * Math.Sin(theta), bpoint.Z)
        Return px
    End Function
You will need a dynamic block with 2 visibility states (the "side" parameter) and 2 attributes , or you can just get rid off that part of the code, and use a simple block with attributes.
Gaston Nunez
vince1327
Message 36 of 36 (227 Views)
02-07-2012 07:24 AM in reply to: gasty1001
Thanks gasty1001,
I actually got it running with help from jeff, sorry for the delayed response. Thanks for the help though!
Announcements
Need installation help?
