.NET
Repeat EXPORTLAYOUT command for all layouts
3 REPLIES 3
970 Views, 3 Replies
Hi
I have drawing with 100 layouts and a want aplay EXPORTLAYOUT to all layouts
EXPORTLAYOUT command asks first for drawing name and than for "Open exported drawing?".
could someone give me a hint how to solve this
Tags (2)
3 REPLIES 3
Virupaksha_aithal
There is no direct API to EXPORTLAYOUT. One workaround is to use script. When you use EXPORTLAYOUT command through scripts, AutoCAD does not show the mentioned prompt.
<SCR FILE>
EXPORTLAYOUT
C:\TEMP\LAYOUT1.DWG
<SCR FILE>
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Below is a link for code created by Tony Tanzillo over at TheSwamp.  There are two different commands available.  One uses the command line and the other does not.
http://www.theswamp.org/index.php?topic=44472.msg497326#msg497326
jeff
in reply to: Keith.Brown
ExportLayout is implemented in .NET and look at the dll with reflector in AutoCAD install folder there is a
AcExportLayoutUI.dll -- actual commands
AcExportLayoutEX.dll
AcExportLayout.dll
You can also find your answers @ TheSwamp
”Boost
