Hello
i want to set render settings like path to save rendered image in , resolution in my plugin.
how can i set this staff.
Hi dj-nemo,
Have you tried using the command line version of the Render command. This will provide you the option to specify the path for the render image.
Try "-Render" inside AutoCAD. You can then pass the same parameters using code.
Hope this helps.
