.NET
Removing objects from selection set
2 REPLIES 2
458 Views, 2 Replies
I am trying to remove one of the object from the selection set.
I am ending in an exception. Can anybody tell me where am I going wrong? A help on this is appreciated.
object[] tempObject = new object[1];
tempObject[0] = (object) acadSelect.Item(objectNumber);
acadSelect.RemoveItems(tempObject);
Where
acadSelect is AcadSelectionSet
objectNumber is static int (care is taken so that this int lies between 0 to acadSelect.Count -1)
2 REPLIES 2
pellacad
Veda...
I wish to use the RemoveItems method to remove some entities from a selections set...very much as you describe here in your message.
Were you able to find a solution?
kbarnettza
in reply to: pellacad
use an array of acad entities ...
like this..
AcadEntity[] oset1 = new AcadEntity[] { (AcadEntity)set1.Item(index) };
otherset.removeitems(oset1);
”Boost
