I have other related posts but felt this was a separate question that could deserve its own post so here goes.
I presently have code that will select objects on screen based on particular stored object handles. The code then prompts the user to add additional selections once these handle selections are made. No problem. The problem lies with attempting to deselect the objects that were selected via object handles. I should say highlighted because that is what the present code is doing. It is highlighting the objects on screen. The code I am using follows:
Dim ids(1) As ObjectId ids(0) = ObjectIdFromHandle(myDocDB, "1D6") ids(1) = ObjectIdFromHandle(myDocDB, "1DE") Autodesk.AutoCAD.Internal.Utils.SelectObjects(ids) ' Get the Pickfirst selection set Dim acSSPrompt As PromptSelectionResult acSSPrompt = ed.SelectImplied() Dim Objs As ObjectIdCollection If acSSPrompt.Status = PromptStatus.OK Then Objs = New ObjectIdCollection(acSSPrompt.Value.GetObjectIds) Else Objs = New ObjectIdCollection End If ed.SetImpliedSelection(New ObjectId(-1) {}) If Objs.Count > 0 Then HighlightEntities(Objs) End If acSSPrompt = ed.GetSelection() If acSSPrompt.Status = PromptStatus.OK Then For Each obj As ObjectId In acSSPrompt.Value.GetObjectIds Objs.Add(obj) Next Dim ids2 As ObjectId() = New ObjectId(Objs.Count - 1) {} Objs.CopyTo(ids, 0) ed.SetImpliedSelection(ids2) End If Private Sub HighlightEntities(objIds As ObjectIdCollection) Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim tr As Transaction = doc.TransactionManager.StartTransaction() Using tr For Each objId As ObjectId In objIds Dim ent As Entity = TryCast(tr.GetObject(objId, OpenMode.ForRead), Entity) If ent IsNot Nothing Then ent.Highlight() End If Next End Using End Sub
Thanks in advance for any help anyone can provide.
Solved by DiningPhilosopher. Go to Solution.
Highlighting and selecting are two very different things.
The problem you have is that you want to allow a user to 'edit' a selection. Unfortunately, there is no built-in API that allows that. It can be done, but involves the use of a kludge.
See this swamp post
I'm not sure I'm reading it right or this is a topic I don't know much about.
But, if you want to deselect something (at this point you should have a SelectionSet built through an ObjectId array - ObjectId[]) can't you just create a new SelectionSet without the ObjectId selected for deselection and then set the new Implied selection?
[CommandMethod("test1", CommandFlags.UsePickSet|CommandFlags.Redraw)] public void test1() { //You may create the original seletion here or already have it at this point //Ask for an object to deselect ObjectId[] MyObjectIds = new ObjectId[count-1]; //Create new selection without the object to deselect newEditor.SetImpliedSelection(MyObjectIds); }
Or maybe what you want is to get the current selection after the deselecting objects (Shift + Click) which would be:
[CommandMethod("test2", CommandFlags.UsePickSet|CommandFlags.Redraw)] public void test2() { Document newDoc = Application.DocumentManager.MdiActiveDocument; Editor newEditor = newDoc.Editor; PromptSelectionResult newPSR = newEditor.SelectImplied(); if (newPSR.Status == PromptStatus.Error) { //This happens when nothing was selected when using SelectImplied() //You may ommit this control and just use the next one, not sure, try it either way. } if (newPSR.Status == PromptStatus.OK) { //Do something with the selection. } }
You need to commandflag UsePickSet to use SelectImplied and that other function correctly.
You need Redraw for your new selection to show properly after using newEditor.Regen(); which you should add at the end of your commands if you want to regenerate the current view of AutoCAD model space.
He wants to give the user ability to operate with previous selected entities (add new primitives to selectionset or remove existing entities from selectionset).
Tony (@DiningPhilosopher) did exactly what @Anonymous asked. And he did it very beautiful in his own style!
ŠŃŠ“ŠæŠ¾Š²ŃŠ“Ń ŠŗŠ¾ŃŠøŃŠ½Š°? ŠŠ»ŃŠŗŠ½ŃŃŃ Š½Š° "ŠŠŠŠŠŠŠŠŠŠ£" ŃŃŠ¼ ŠæŠ¾Š²ŃŠ“Š¾Š¼Š»ŠµŠ½Š½ŃŠ¼! | Do you find the posts helpful? "LIKE" these posts!
ŠŠ°Ń
Š¾Š“ŠøŃŠµ ŃŠ¾Š¾Š±ŃŠµŠ½ŠøŃ ŠæŠ¾Š»ŠµŠ·Š½ŃŠ¼Šø? ŠŠ¾ŃŃŠ°Š²ŃŃŠµ "ŠŠ ŠŠŠŠ¢Š”ŠÆ" ŃŃŠøŠ¼ ŃŠ¾Š¾Š±ŃŠµŠ½ŠøŃŠ¼!
ŠŠ° Š²Š°ŃŠµ Š·Š°ŠæŠøŃŠ°Š½Š½Ń Š²ŃŠ“ŠæŠ¾Š²ŃŠ»Šø? ŠŠ°ŃŠøŃŠ½ŃŃŃ ŠŗŠ½Š¾ŠæŠŗŃ "ŠŠ ŠŠŠŠÆŠ¢Š Š ŠŠØŠŠŠŠÆ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
ŠŠ° Š²Š°Ń Š²Š¾ŠæŃŠ¾Ń ŃŃŠæŠµŃŠ½Š¾ Š¾ŃŠ²ŠµŃŠøŠ»Šø? ŠŠ°Š¶Š¼ŠøŃŠµ ŠŗŠ½Š¾ŠæŠŗŃ "Š£Š¢ŠŠŠ ŠŠŠ¢Š¬ Š ŠŠØŠŠŠŠ"
Alexander Rivilis / ŠŠ»ŠµŠŗŃŠ°Š½Š“Ń Š ŠøŠ²ŠøŠ»ŠøŃ / ŠŠ»ŠµŠŗŃŠ°Š½Š“Ń Š ŃŠ²ŃŠ»ŃŃ
Programmer & Teacher & Helper / ŠŃŠ¾Š³ŃŠ°Š¼Š¼ŠøŃŃ - Š£ŃŠøŃŠµŠ»Ń - ŠŠ¾Š¼Š¾ŃŠ½ŠøŠŗ / ŠŃŠ¾Š³ŃŠ°Š¼ŃŃŃ - Š²ŃŠøŃŠµŠ»Ń - ŠæŠ¾Š¼ŃŃŠ½ŠøŠŗ
Facebook | Twitter | LinkedIn
hmm...Never heard of a kludge. I will need to look into this. I will also look at the swamp post and see what I can make work. Thanks for the link DiningPhilosopher
Alexander, was your response to Tony a sarcastic response or do you agree with Tony's response and Swamp post? Just curious. š
Thanks, I will let you know how I make out.
No sarcasm! I respect Tony for his knowledge and for the fact that he shares this knowledge with others. I believe that this forum is at a high level thanks to Tony! If you do not be lazy and read this forum, you will find that Tony answers the questions more than a dozen years. He's the only one who dedicate a separate topic on this forum.
ŠŠ°Ń
