.NET
glanard
Message 1 of 4 (264 Views)
Remove One SelectionSet to Another One
264 Views, 3 Replies
02-29-2012 09:43 AM
Assuming the model space is active with a zoom extents, my question is:
I have 2 selection sets:
- ssA= The first one that contains all the entities (SelectAll).
- ssB= The second one that as been made using the SelectCrossingWindow method.
What I want is to remove the 2nd selection set from the first one: in other words, to get (ssA-ssB).
In VBA, I remember we had a RemoveItems method, but it seems not in VB.NET.
Have you an idea to make this substraction?
I repeat that ssB contains SelectedObjectByWindow...
Hallex
Message 2 of 4 (237 Views)
Re: Remove One SelectionSet to Another One
03-01-2012 09:59 AM in reply to: glanard
You might want to look closely at FromObjectIds method:
Dim newSset As SelectionSet  = SelectionSet.FromObjectIds(ids)
See docs
~'J'~
glanard
Message 3 of 4 (224 Views)
03-01-2012 11:28 PM in reply to: glanard
Hi all,
Thanks...
but I found the answer by myself before :smileytongue:
Something like:
ssA = New ObjectIdCollection(objSS.GetObjectIds())
for each objId As ObjectID in ssB.GetObjectIds()
     ssA.Remove(objId)
next
Hallex
Message 4 of 4 (215 Views)
03-02-2012 01:50 AM in reply to: glanard
Good point
If this is interesting for somebody else
here is how to apply FromObjectIds method to solve this task
{code}
       <CommandMethod("SELWP")> _
        Public Sub WindowPolygonSelect()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim aset As ObjectIdCollection = Nothing
            Dim bset As List(Of ObjectId) = Nothing
            Dim ppo As New PromptPointOptions(vbLf & "Pick first corner: ")
            Dim res As PromptPointResult
            res = ed.GetPoint(ppo)
            If res.Status <> PromptStatus.OK Then
                Return
            End If
            Dim p1 As Point3d = res.Value
            Dim pco As New PromptCornerOptions(vbLf & "Pick opposite corner: ", p1)
            pco.BasePoint = p1
            pco.UseDashedLine = True
            res = ed.GetCorner(pco)
                Return
            End If
            Dim p2 As Point3d = res.Value
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Dim sresA As PromptSelectionResult
                    Dim filterList(,) As Object = New Object(,) {{-4, "<or"}, {0, "text"}, {0, "mtext"}, {0, "dimension"}, {0, "insert"}, {0, "leader"}, {-4, "or>"}}
                    Dim tvs(filterList.GetUpperBound(0)) As TypedValue
                    For i As Integer = 0 To filterList.GetUpperBound(0)
                        tvs(i) = New TypedValue(Convert.ToInt32(filterList(i, 0)), filterList(i, 1))
                    Next
                    Dim filt As SelectionFilter = New SelectionFilter(tvs)
                    sresA = ed.SelectCrossingWindow(p1, p2, filt)
                        Return
                    End If
                    Dim ssA As SelectionSet
                    ssA = sresA.Value
                    If ssA Is Nothing Then
                        ed.WriteMessage(vbLf & "Nothing selected...")
                        Return
                    End If
                    ed.WriteMessage(vbLf & "Selected by crosing window:   {0}", ssA.Count)
                    Dim idsA As ObjectId() = ssA.GetObjectIds
                    aset = New ObjectIdCollection(idsA)
                    Dim sresB As PromptSelectionResult
                    sresB = ed.SelectAll
                    ed.WriteMessage(vbLf & "Selected all:   {0}", sresB.Value.Count)
                    Dim ssB As SelectionSet
                    bset = New List(Of ObjectId)
                    ssB = sresB.Value
                    If ssB Is Nothing Then
                        Return
                    End If
                    Dim idsB As ObjectId() = ssB.GetObjectIds
                    For Each id As ObjectId In idsB
                        If Not aset.Contains(id) Then
                            bset.Add(id)
                        End If
                    Next
                    ssB = SelectionSet.FromObjectIds(bset.ToArray)
                    ed.SetImpliedSelection(ssB)
                    ed.WriteMessage(vbLf & "Now in selection is :   {0}", ssB.Count)
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                MsgBox(ex.Message + vbCrLf + ex.StackTrace)
            Finally
            End Try
        End Sub
{code}
~'J'~
