.NET
remove attrbute from block
5 REPLIES 5
imagination_s
694 Views, 5 Replies
Hi Everyone
I have a block with 2 attributes .I want to remove a attribute unsing vb net or C#
Please help
5 REPLIES 5
SENL1362
in reply to: imagination_s
from block or blockreference?
imagination_s
in reply to: SENL1362
From blockreference
SENL1362
this article show you how to LIST attributeReferences.
http://through-the-interface.typepad.com/through_the_interface/2006/09/getting_autocad.html
Instead of writing the attribute to the screen add an Erase for the attributeReference with the TAG you have in mind.
imagination_s
Thankyou so much for your help
Seth007
Did u solve your problem? Could you share your solution?
”Boost
