.NET
Remember Input
2 REPLIES 2
319 Views, 2 Replies
Remember Input
I've tried to get a distance with following code.
When i do it the first time it should just ask for the distande.
The next time it should use the last distance as the default value.
But when i use the default value by entering enter, the next time it will use <0> as the default distance. But why?
What do i have to do to get allways the right distance as the default value.
I also want to remember the last input of the distance and the lenght in this drawing just for this session, like in acad. And i would like to remember it for each drawing.
I don't want the same distance for all drawings (like in command offset).
What would be the best way to do this? XRecords instead of Events? Maybe there is an example somewhere.
[code]#region Using directives
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.DatabaseServices;
using System.Threading;
using System.Globalization;
#endregion
namespace RSNNAcadApp.Test
public class Test
static PromptDistanceOptions useThisDistanceOption;
static PromptDoubleResult useThisDistanceResult;
private double Dist;
private int Luprec = Application.DocumentManager.MdiActiveDocument.Database.Luprec;
public Test()
Database db = Application.DocumentManager.MdiActiveDocument.Database; //oder: entid.Database;
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
Thread.CurrentThread.CurrentCulture = new CultureInfo("en-us");
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
PromptDistanceOptions opt1 = new PromptDistanceOptions("Abstand zeigen");
opt1.AllowNegative = false;
opt1.AllowZero = false;
opt1.AllowNone = false;
opt1.UseDashedLine = true;
PromptDoubleResult res = null;
if (useThisDistanceResult != null)
res = useThisDistanceResult;
Dist = res.Value;
string DistKeyword = Dist.ToString("F" + Luprec.ToString());
opt1.DefaultValue = Dist;
else
//USAGE OF INPUT CONTEXT REACTORS
ed.PromptingForDistance += new PromptDistanceOptionsEventHandler(handle_promptDistanceOptions);
ed.PromptedForDistance += new PromptDoubleResultEventHandler(handle_promptDistanceResult);
res = ed.GetDistance(opt1);
ed.PromptingForDistance -= new PromptDistanceOptionsEventHandler(handle_promptDistanceOptions);
ed.PromptedForDistance -= new PromptDoubleResultEventHandler(handle_promptDistanceResult);
if (res.Status == PromptStatus.OK)
Dist = res.Value;
ed.WriteMessage(String.Format("Abstand = {0}", Dist.ToString()));
else
return;
private static void handle_promptDistanceOptions(object sender, PromptDistanceOptionsEventArgs e)
useThisDistanceOption = e.Options;
private static void handle_promptDistanceResult(object sender, PromptDoubleResultEventArgs e)
useThisDistanceResult = e.Result;
}[/code]
Roland
2 REPLIES 2
How about this?
using System;
using System.Text;
#endregion
public class Test
private double m_dist; //last distance chosen (per-document)
private bool m_firstTime = true; //first invocation of "test"?
(per-document)
//use a non-static command method so the enclosing class (Test) will
be instantiated
//for each document
[CommandMethod("test")]
public void DoIt()
Editor ed =
zeigen");
if (!m_firstTime)
opt1.DefaultValue = m_dist;
PromptDoubleResult res = ed.GetDistance(opt1);
m_dist = res.Value;
m_dist.ToString()));
m_firstTime = false;
wrote in message news:4860287@discussion.autodesk.com...
using System;
using System.Text;
#endregion
public class Test
public Test()
Database db =
entid.Database;
Editor ed =
zeigen");
Dist = res.Value;
else
Dist = res.Value;
Dist.ToString()));
else
return;
}[/code]
Roland
Thank you Albert,
i think that's what i wanted 😉
Roland
”Boost
