.NET
release object
0 REPLIES 0
Message 1 of 1
wesbird
211 Views, 0 Replies
release object
When I draw a line or offset a pline, I need to use
BlockTableRecord.AppendEntity
Transaction.AddNewlyCreatedDBObject
to add to AutoCAD database. but how about I don't want to add them to AutoCAD database? I just need this line(pline) for calculation, or find the intersection point with other AutoCAD Object. in VBA, I will delete them afterward. How is in .NET? Just simple NOT add to database? Should I release them with Close() or Dispose()?
btw, what's the difference between Close() or Dispose()?
I tried to run Curve.Close(), and get a compile warning:
xxxx.cs(887,7): warning CS0618: 'Autodesk.AutoCAD.DatabaseServices.DBObject.Close()' is obsolete: 'Use Transaction instead'
Thank you and appreciate your help
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
0 REPLIES 0
”Boost
