.NET
Reinventing the wheel, or how to found the closest vertex of polyline?
2 REPLIES 2
DeZert
492 Views, 2 Replies
I keep asking simple questions.. Smiley Embarassed
I have a point on polyline (not vertex!) as Point3D, and I need to find closest vertex of polyline.
In other words, I put a points on the polyline, and they should not be located closer than 50 meter vertices of the polyline. For this I need to find closest vertex to point.
Previously sorry for my wrong English )
2 REPLIES 2
_gile
in reply to: DeZert
If the input point is on the polyline, you can get its parameter (double).
Parameters of polylines are integer on vertices, so it's easy to get the closest vertex.
Point3d closestVertex =
    pline.GetPointAtParam(Math.Round(pline.GetParamAtPoint(inputPoint)));
Gilles Chanteau
GileCAD
GitHub
DeZert
in reply to: _gile
Very thanks!
”Boost
