.NET
Region.CreateFromCurves() issues
5 REPLIES 5
bej
2342 Views, 5 Replies
I'm working on an application that converts Polyline3D objects into Region objects. The routine works as follows:
1. create a polyline3d object from a set of vertixes (the shape is always closed)
2. add polyline3d to DBObjectCollection
3. Call Region.CreateFromCurves(acDBObjColl);
Most of the times this routine works fine, but depending on the shape of the polyline3d, the CreateFromCurves() method will fail with an exception error eInvalidInput. When this happens multiple times in a file, autocad will eventually crash/become unstable.
My question is: is there a smart way to check if a polyline3d is a valid Region element before attempting to run it through Region.CreateFromCurves()?
Below is some sample code showing the issue:
Polyline3d face = new Polyline3d(Poly3dType.SimplePoly, vertices, true);
DBObjectCollection acDBObjColl.Add(face);
DBObjectCollection myRegionColl;
try
  myRegionColl = Region.CreateFromCurves(acDBObjColl);
catch()
// eInvalidInput exception
  Debug.WriteLine("Error: unable to create region collection: " + ex->Message);//
Regards
Bjørn Egil Jenssen
5 REPLIES 5
_gile
in reply to: bej
hi,
It seems to me the curves passed to CreateFromCurves have to lie on the same plane. Are you sure your Polyline3d are stricly planar ?
Gilles Chanteau
GileCAD
GitHub
bej
in reply to: _gile
I'm testing if the polyline is in a plane before passing it to a region. But the main issue I'm having is to have a method to check if a polyline is valid on all points (planar, non-intersecting, closed, etc) before passing it to CreateFromCurves(). Is there a method that does this kind of verification? What requirements do a polyline3d have to fullfill to be a used as a Region?
Reg.
Bjørn Egil Jenssen
bej
in reply to: bej
Alternativly, is there a way to safely handle sending an invalid polyline3d to CreateFromCurves()?
Reg.
Bjørn Egil Jenssen
SEANT61
in reply to: bej
Another issue that may come into play - with regard to decreasing AutoCAD stability – is the ultimate fate of that newly created Polyline3d.
You may already have this set up in some latter portion of code but; unless committed via Transaction, the poly3d needs to be disposed.
May your cursor always snap to the location intended.
Hallex
in reply to: bej
Bjørn,
Try use this code snip instead (just an idea not tested)
                DBObjectCollection objColl = new DBObjectCollection();
                Polyline3d face = new Polyline3d();
	//ETC...
                // or from your settings
                // Polyline3d face = new Polyline3d(Poly3dType.SimplePoly, vertices, true);
                if (!face.IsPlanar)
                    throw new System.Exception("out of luck, bud, it ought be planar");
                else
                    objColl.Add(face);
                    DBObjectCollection myRegionColl = new DBObjectCollection();
                    // create a single region
                    Autodesk.AutoCAD.DatabaseServices.Region objreg = new Autodesk.AutoCAD.DatabaseServices.Region();
                    DBObjectCollection objRegions = new DBObjectCollection();
                    try
                        objRegions = Autodesk.AutoCAD.DatabaseServices.Region.CreateFromCurves(objColl);
                        objreg = objRegions[0] as Autodesk.AutoCAD.DatabaseServices.Region;
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("Error: unable to create region collection:\n" + ex.Message);
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
