.NET
Valued Contributor
fmarcelino
Message 1 of 7 (321 Views)
Regen layer
321 Views, 6 Replies
04-18-2006 06:58 AM
I wonder if it's possible to regen only one layer.
Thanks in advance for your attention,
Filipe Marcelino
*Tony Tanzillo
Message 2 of 7 (321 Views)
Re: Regen layer
04-18-2006 01:26 PM in reply to: fmarcelino
Reference AcMgdInternal.dll, and then use:
Autodesk.AutoCAD.Internal.LayerUtilities.RegenLayers(
ObjectId[] layers, int regenPending);
The first parameter is an array contianing the ObjectId's
of the LayerTableRecords for the layers to be regenerated.
For the second parameter, pass the result of this
static property on the same class:
Autodesk.AutoCAD.Internal.LayerUtilties.RegenPending;
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5145597@discussion.autodesk.com...
Filipe Marcelino
Valued Contributor
fmarcelino
Message 3 of 7 (321 Views)
Re: Regen layer
04-19-2006 03:30 AM in reply to: fmarcelino
Thanks for your response Tony, but I can't find that DLL. Shouldn't be in 'inc' folder of the ObjectARX?
Filipe Marcelino
*Kerry Brown
Message 4 of 7 (321 Views)
Re: Regen layer
04-19-2006 04:17 AM in reply to: fmarcelino
Have a look in the ACAD root folder
wrote in message news:5146847@discussion.autodesk.com...
ObjectARX?
Filipe Marcelino
Active Contributor
Somepin
Message 5 of 7 (321 Views)
Re: Regen layer
06-02-2006 04:45 PM in reply to: fmarcelino
Will be obvious soon enough-I'm new to the managed wrappers and objectarx although not to .NET.
I can't even guess how many hours I've spent trying to get a block with subentities on layer X to change color like everything else on the layer does when updatescreen() is called without having to resort to using regen(AcAllVP).. Thanks soooooooooooo much!!!
Now... Since AcMgdInternal.dll is not mentioned at all in the SDK, how should I go about discovering this and any other information I might need in the future that 'desk has ommitted? Message was edited by: Somepin
Also, If you have time can you give me some code describing how to "regen" (in whatever form it exists) an object/layer/the drawing? These blocks i created were just to feel up the object model. They consist of an "X" (2 lines). In one block, the lines are on layer 0 and in the other they are on layer 1. Both blocks are inserted to layer 0 and then both copied onto layers 1,2,3,etc. When layer "1" for instance is changed some (but not all) of the blocks completely change colors as desired, and of course any non-complex objects change as well. Without Internal.dll, does the involve iterating, and if so, through what db/dic/XX? THANKS again soooo much!
Active Contributor
harryliu3140
Message 6 of 7 (187 Views)
Re: Regen layer
11-20-2013 03:52 PM in reply to: fmarcelino
You don't need to reference AcMgdInternal.dll. The Autodesk.AutoCAD.Internal may be included in AcDbMgd or AcMgd.
Valued Mentor
fieldguy
Message 7 of 7 (155 Views)
Re: Regen layer
11-21-2013 07:30 AM in reply to: harryliu3140
Just to clarify - Autocad 2009 requires a reference to AcMgdInternal.dll.  2012 does not.  I don't know when then APIs changed.
