.NET
RegAppTable.Has(appname) always return false?
1 REPLY 1
529 Views, 1 Reply
Warning: I am a newbie to this forum and working with Autodesk .Net API....
Senario, I am registering the application name in th RegAppTable. It seems to have worked becuase when I save the drawing as a DXF file and I open it in a text editor I can find the application name is in the DXF. However if I reopen the drawing and run that code it ALWAYS returns false!?!
I am not understanding the RegAppTable or is this a bug?
      using (Transaction tr = db.TransactionManager.StartTransaction()) {
            // Open the Registered Applications table for read
            RegAppTable rat = tr.GetObject(db.RegAppTableId, OpenMode.ForRead) as RegAppTable;
            // Check to see if the Registered Applications table record for the custom app exists
            if (rat.Has(APPNAME) == false) {
               using (RegAppTableRecord ratRec = new RegAppTableRecord()) {
                  ratRec.Name = APPNAME;
                  rat.UpgradeOpen();
                  rat.Add(ratRec);
                  tr.AddNewlyCreatedDBObject(ratRec, true);
Windows 8.1 w/ Visual Studio 2013 & AutoCAD 2015
1 REPLY 1
norman.yuan
Although you said you can see the XData application name after saving the drawing as DXF file, I suspect the application being existing may not be the result of your code execution, because in yor code the Transaction is NOT COMMITED, thus, you code shown here that adds a RegAppTableRecord into Database's RegAppTable eventaully will be be aborted at the end of the Transaction.
Norman Yuan
Drive CAD With Code
”Boost
