.NET
Reg. StandALone application
1 REPLY 1
dhimant.bhensdadia
365 Views, 1 Reply
Is it poosible to make EXE file (StandAlone) apllication in .NET for AutoCAD customization using .NET API ?
.NET API means using DataBase services, Transaction...etc...
1 REPLY 1
_gile
in reply to: dhimant.bhensdadia
AutoCAD .NET API only runs in-process.
ActiveX may be run out of process.
You can get an AutoCAD runing process or start a new one from your stand-alone application and then, load a.NET assembly and run some command(s) defined in it.
See here.
Gilles Chanteau
GileCAD
GitHub
”Boost
