.NET
Refresh object with Overruled.WorldDraw
2 REPLIES 2
pva75
464 Views, 2 Replies
I have object with overruled WorldDraw.
In this method I draw some information about object.
Next I change some properties of this object and have to refresh information.
If I call editor.Regen() it works but performance is not good.
Editor.UpdateScreen() is not enouht.
Can I update overruled only for one object not for all scheme?
Pavel
2 REPLIES 2
Hallex
in reply to: pva75
Take a look at this thread:
http://forums.autodesk.com/t5/NET/Overrule-a-specific-subentity-in-block-and-not-showing-the-Base/td...
this one is might be useful for you
~'J'~
pva75
in reply to: Hallex
Works as:
publicstaticvoid RefreshObject(Entityobj)
  if(!obj.Visible)
      return;
  if(!obj.IsWriteEnabled)
         obj.UpgradeOpen();
     obj.Visible = false;
     obj.Visible = true;
”Boost
