.NET
.NET
Active Member
JuramemO
Message 1 of 7 (360 Views)
Refresh drawing after block modivication
360 Views, 6 Replies
11-26-2013 08:41 AM
Dear all!
My code mirrors a selection by either the x-axis or the y-axis.
It is working fine.
Exept, the drawing shows the result, when I move my cursor to the active dwg.
How can I refresh my drawing, direct after modification of a block?
Any sugestions to a clean solution?
Thank you!
I use the code below to mirror a selected block by a button on a docking pallette:
private void btn_Vertical_Mirror_Click(object sender, EventArgs e)
	(new Modifikation()).Mirror("v");
the code, which is called is:
public void Mirror(String axis = "")
	Document dwg = Application.DocumentManager.MdiActiveDocument;
	Database db = dwg.Database;
	Editor edt = dwg.Editor;
	try
		Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
		PromptSelectionResult sel = edt.SelectImplied();
		if (sel.Status == PromptStatus.Error)
			//Selection filter
			TypedValue[] tv = new TypedValue[] { new TypedValue( (int)DxfCode.Start, "INSERT") };
			SelectionFilter sf = new SelectionFilter(tv);
			PromptSelectionOptions pso = new PromptSelectionOptions();
			pso.MessageForAdding = "\nSelect block";
			sel = edt.GetSelection(pso, sf);
			if (sel.Status != PromptStatus.OK)//
				edt.WriteMessage("\n#ERROR! Selection failed\n");
				return;
			}//if
		while (axis == "")
			axis = edt.GetString("Axis ('H'orizontaly oder 'V'erticaly)").StringResult.ToUpper();
			if (axis.StartsWith("H")) { axis = "h"; }
			else if (axis.StartsWith("V")) { axis = "v"; }
			else { axis = ""; }
		using (Transaction tr = db.TransactionManager.StartTransaction())
			using (DocumentLock lk = dwg.LockDocument())
				for (int i = 0; i < sel.Value.Count; i++)
					if (sel.Value[i].ObjectId.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(BlockReference))))// Blöcke werden der Auswahl entnommen
						BlockReference blk_ref = (BlockReference)tr.GetObject(sel.Value[i].ObjectId, OpenMode.ForWrite);
						if (axis == "h")
							Matrix3d spgl = Matrix3d.Mirroring(
								new Line3d(
									blk_ref.Position,
									new Point3d(
										blk_ref.Position.X + 1,
										blk_ref.Position.Y, 0)));
							blk_ref.TransformBy(spgl);
						else if (axis == "v")
								new Line3d(
									blk_ref.Position,
									new Point3d(
										blk_ref.Position.X,
										blk_ref.Position.Y + 1, 0)));
					}//if
				}// for
			}// using DocumentLock
			tr.Commit();
		}// using Transaction
		edt.WriteMessage("\nOkay\n");
	}// try
	catch { edt.WriteMessage("\n#Error!\n"); }
	finally { edt.WriteMessage("\nDone\n"); }
}// public void
try by adding this line at the end of your code
'' Regenerate the drawing
edt.Regen()
 http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/files/WS1a9193826455f5ff2566ffd511ff6f8c7ca-42db.htm
Valued Mentor
Ajilal.Vijayan
Message 2 of 7 (352 Views)
Re: Refresh drawing after block modivication
11-26-2013 09:06 AM in reply to: JuramemO
edt.Regen()
 http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/files/WS1a9193826455f5f...
Active Member
JuramemO
Message 3 of 7 (340 Views)
11-26-2013 09:56 AM in reply to: Ajilal.Vijayan
Hallo and thank you for your fast and competent reply!
Thank's, once more!
ADN Support Specialist
StephenPreston
Message 4 of 7 (309 Views)
11-26-2013 02:02 PM in reply to: JuramemO
Calling Regen can be a tad slow for a large drawing. When I've modified a BlockTableRecord, I prefer to iterate through all the BlockReferences for that BlockTableRecord and call RecordGraphicsModified(0 on each one. Something like this:
   http://adndevblog.typepad.com/autocad/2012/05/redefining-a-block.html
Its personal choice really - just mentioning this for others who may find this post in the future.
Cheers,
Stephen Preston
Autodesk Developer Network
Active Member
JuramemO
Message 5 of 7 (287 Views)
11-27-2013 10:49 AM in reply to: StephenPreston
Hi Stephen!
Some kind of loop was also my first idea.
I tryed to refresh my drawing by using the code below.
It's a function, which is called after closing the transaction.
private void RefreshBlocks()
  if (sel.Status == PromptStatus.Error) { sel = edt.SelectAll(); }
  try
        for (int i = 0; i < sel.Value.Count; i++)// Loop objects
          if (sel.Value[i].ObjectId.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(BlockReference))))// proceed only blocks
            blk_ref.RecordGraphicsModified(true);
          }// if
        }// for
      tr.Commit();
  }// try
  catch { }
But something is wrong. The changes on the block are not shown, until i set the focus to the drawing.
By calling < regen > everything goes well.
Can you point your finger to the mistake or error of the code?
Thank you!
_gile
Message 6 of 7 (280 Views)
11-27-2013 12:26 PM in reply to: JuramemO
You can try adding:
db.TransactionManager.QueueForGraphicsFlush();
 after each:
Gilles Chanteau
Active Member
JuramemO
Message 7 of 7 (269 Views)
11-28-2013 01:11 AM in reply to: JuramemO
After playing around I finaly have a (partial) solution.
I insered the following rows to my code:
    dwg.TransactionManager.EnableGraphicsFlush(true);// new
	// Code for modification of the block(s)
    db.TransactionManager.QueueForGraphicsFlush();// new
dwg.TransactionManager.FlushGraphics();// new
tr.Commit();
BUT!! It showes some strainge behaviour:
Rotating of blocks is working fine.
Mirroring of blocks is only working, by selecting the blocks by a < edt.GetSelection(pso, sf) > command.
Using  < edt.SelectImplied(); >, the updating of the drawing fails (must be triggered by activating by the operator)
I can overcome this, by using the code below.
But it looks not nice to me.
if (sel.Status == PromptStatus.OK)
  ObjectId[] sel_tmp = new ObjectId[sel.Value.Count];
  for (int i = 0; i < sel.Value.Count; i++) temp_sel[i] = sel.Value[i].ObjectId;
  edt.SetImpliedSelection(new ObjectId[0]);
  edt.SetImpliedSelection(sel_tmp);
}// if
