.NET
Refering to the 3D objects in a .FBX file
1 REPLY 1
398 Views, 1 Reply
Hi All
Does anyone know how to refer to the 3D objects in a .FBX file using X-data attached to the object or the object handle?
1 REPLY 1
philippe.leefsma
Do you mean that you exported an acad drawing containing objects with xdata attached and you want to retrieve them in the fbx? If I misunderstood, please clarify the question.
Did you take a look at the fbx sdk? I am not familiar with it personally unfortunately:
http://www.autodesk.com/products/fbx/overview
If the question is more fbx oriented, you may want also ask the question on our M&E oriented progarmming forums.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
”Boost
