.NET
Reference required to assembly.... error
4 REPLIES 4
342 Views, 4 Replies
I have the following references loaded....
AutoCAD 2006 Type Library 1.1
AutoCAD/ObjectDBX Common 16.0 Type Library
But my 'common' will not show up, for example this line of code is not
recognized.
Dim Thisdrawing As Autodesk.AutoCAD.Interop.AcadDocument
Any suggestions ??
4 REPLIES 4
Look at your object browser and it'll tell you that AcadDocument is off of
Interop.Common or use:
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Then you can use:
Dim Thisdrawing As AcadDocument
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
If AcadDocument is off, how do you get it back on ??
"Mike Tuersley" wrote in message
news:4958311@discussion.autodesk.com...
Then you can use:
-- Mike
Mike Tuersley
No 😃 "OFF OF" meaning you get to AcadDocument by walking the tree
Autodesk.AutoCAD.Interop.Common.AcadDocument not the way you were. You were
missing the .COMMON
-- Mike
Mike Tuersley
I got it fixed. Just did a repair of my Mechanical Desktop, all is good.
Then you can use:
-- Mike
Mike Tuersley
”Boost
