.NET
Recover Drawing
2 REPLIES 2
peteh
737 Views, 2 Replies
Recover Drawing
Does anyone have any vb.net code to recover an AutoCAD 2013 drawing?
2 REPLIES 2
Virupaksha_aithal
in reply to: peteh
At present there is no programmatic way of recovering the drawing files. One method is to create a script file which can recover the drawing file and running the script through the code.
Script file could be like
Recover
c:\temp\test.scr
VB.net code
<CommandMethod("testrecover", CommandFlags.Session)> _
   Sub testrecover()
        Dim scriptPath As String = "c:\\temp\\recover.scr"
        Dim oApp As AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
        oApp.ActiveDocument.SendCommand("(command ""script"" """ & scriptPath & """)" & vbCrLf)
    End Sub
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
peteh
in reply to: peteh
I can make this work...  thank you.
”Boost
