What is the point of clicking on Recover if the file is ALWAYS invalid and can't be used or is it just my luck. Using 2012 Civil 3D (hopefully for not much longer). Whenever I get a fatal error, the option to create a recovery file pops and up and I always click yes. After I get kicked out and create the error report, I re-launch the program and in it's selection of files there is a Recovery File. It never opens and says the file is invalid. Am I doing something wrong? I have also tried using the command "Recover" and selecting that file but I still get "Unable to recover drawing file". The recovery file is always very small in size by comparison to the original.
Solved by tyronebk. Go to Solution.
Most probably your code is corrupting the database, that's why the crash and that's why the invalid file, show the code.
Gaston Nunez
