.NET
record history doesn't work on creating an extruded hehagon
7 REPLIES 7
Message 1 of 8
dancalgary
546 Views, 7 Replies
I am trying to create an extruded hexagon
EVERYTHING WORKS.... BUT:
after the creation of the hexagon the grips are not available even i added the proper code
(Polygon3d.record history = true)
Can somebody help me?
See bellow my function.
    Public Function extrude_Hexagon(ByVal Centre_point As Point3d, ByVal radius_hexagon As Double, ByVal height_hexagon As Double) As Solid3d
        Try
            Dim ThisDrawing As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim Editor1 As Autodesk.AutoCAD.EditorInput.Editor = ThisDrawing.Editor
            Using Lock1 As DocumentLock = ThisDrawing.LockDocument
                Using Trans1 As Autodesk.AutoCAD.DatabaseServices.Transaction = ThisDrawing.TransactionManager.StartTransaction
                    Dim BTrecord As Autodesk.AutoCAD.DatabaseServices.BlockTableRecord = Trans1.GetObject(ThisDrawing.Database.CurrentSpaceId, OpenMode.ForWrite)
                    Dim Poly1 As New Autodesk.AutoCAD.DatabaseServices.Polyline
                    Dim Point00 As New Point2d(Centre_point.X + radius_hexagon, Centre_point.Y)
                    Dim Point01 As New Point2d(Centre_point.X + radius_hexagon * Cos(PI / 3), Centre_point.Y + radius_hexagon * Sin(PI / 3))
                    Dim Point02 As New Point2d(Centre_point.X - radius_hexagon * Cos(PI / 3), Centre_point.Y + radius_hexagon * Sin(PI / 3))
                    Dim Point03 As New Point2d(Centre_point.X - radius_hexagon, Centre_point.Y)
                    Dim Point04 As New Point2d(Centre_point.X - radius_hexagon * Cos(PI / 3), Centre_point.Y - radius_hexagon * Sin(PI / 3))
                    Dim Point05 As New Point2d(Centre_point.X + radius_hexagon * Cos(PI / 3), Centre_point.Y - radius_hexagon * Sin(PI / 3))
                    Poly1.AddVertexAt(0, Point00, 0, 0, 0)
                    Poly1.AddVertexAt(1, Point01, 0, 0, 0)
                    Poly1.AddVertexAt(2, Point02, 0, 0, 0)
                    Poly1.AddVertexAt(3, Point03, 0, 0, 0)
                    Poly1.AddVertexAt(4, Point04, 0, 0, 0)
                    Poly1.AddVertexAt(5, Point05, 0, 0, 0)
                    Poly1.Closed = True
                    Dim Segments_collection As New DBObjectCollection
                    Poly1.Explode(Segments_collection)
                    Dim Colectie_Regiune As New DBObjectCollection
                    Colectie_Regiune = Autodesk.AutoCAD.DatabaseServices.Region.CreateFromCurves(Segments_collection)
                    Dim Regiunea As New Region
                    Regiunea = Colectie_Regiune(0)
                    Dim Polygon3d As New Solid3d
                    Polygon3d.RecordHistory = True
                    Polygon3d.Extrude(Regiunea, height_hexagon, 0)
                    BTrecord.AppendEntity(Polygon3d)
                    Trans1.AddNewlyCreatedDBObject(Polygon3d, True)
                    Trans1.Commit()
                    Return Polygon3d
                End Using
            End Using
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Function
7 REPLIES 7
Message 2 of 8
Hallex
in reply to: dancalgary
Change the logic in your function,
declare object before of "Try" code block,
there is a quick edition:
            Dim Polygon3d As Solid3d = Nothing
            Try
                        Dim Point01 As New Point2d(Centre_point.X + radius_hexagon * Math.Cos(Math.PI / 3), Centre_point.Y + radius_hexagon * Math.Sin(Math.PI / 3))
                        Dim Point02 As New Point2d(Centre_point.X - radius_hexagon * Math.Cos(Math.PI / 3), Centre_point.Y + radius_hexagon * Math.Sin(Math.PI / 3))
                        Dim Point04 As New Point2d(Centre_point.X - radius_hexagon * Math.Cos(Math.PI / 3), Centre_point.Y - radius_hexagon * Math.Sin(Math.PI / 3))
                        Dim Point05 As New Point2d(Centre_point.X + radius_hexagon * Math.Cos(Math.PI / 3), Centre_point.Y - radius_hexagon * Math.Sin(Math.PI / 3))
                        Poly1.Closed = True
                        Polygon3d = New Solid3d
                        Polygon3d.ShowHistory = True
                        Trans1.Commit()
                    End Using
                End Using
                Polygon3d = Nothing
                MsgBox(ex.Message)
            End Try
            Return Polygon3d
        End Function
Message 3 of 8
dancalgary
in reply to: Hallex
I have changed as per your instructions but no luck
my hexagon is still without history
Message 4 of 8
Hallex
Mine is have one, see piccy
Message 5 of 8
dancalgary
in reply to: Hallex
vb.net code creates the red extruded hexagon
the yellow one i did it manualy
I think I have an error in my code
I should try to use the polyline?
Message 6 of 8
Hallex
Yes you can, instead of exploding a polyline
use this code snip:
                        Segments_collection.Add(Poly1)
		'Rest code is the same
Message 7 of 8
dancalgary
in reply to: Hallex
    Public Function Creaza_Hexagon(ByVal Centre_point As Point3d, ByVal radius_hexagon As Double, ByVal height_hexagon As Double) As Solid3d
        Try
                    Poly1.Closed = True
                    Poly1.TransformBy(Matrix3d.Displacement(Poly1.GetPointAtParameter(0).GetVectorTo(New Point3d(Centre_point.X + radius_hexagon, Centre_point.Y, Centre_point.Z))))
                    Trans1.Commit()
                End Using
            End Using
            Polygon3d = Nothing
            MsgBox(ex.Message)
        End Try
        Return Polygon3d
    End Function
I still have the same problem
I do have just 1 grip
This one is manually created
See code used above.
Message 8 of 8
junoj
It appears that not all solids are created equally. If you ‘list’ both solids (manual & code) you will see that the manual solid is classified by CAD as SOLID TYPE = Extrusion, and it has an EXTRUSION HEIGHT property.
The one created by code is just a regular solid (if you union two Extrusions you get a regular solid like the one created by code).
If you need more grips you can hold down the Ctrl button and select the solid with a window (lower right to upper left) you will see additional grips available on both Solids (manual and code), the only grip missing on the ‘code’ solid is the ‘Height’ grip.
I am currently using AutoCAD 2008. Perhaps AutoDesk has added the Height property to the newer version of AutoCAD or created a New Extrusion type class in the new AutoCAD. I don’t have the new CAD to check.
”Boost
