.NET
Realy slow startup AutoCAD
6 REPLIES 6
385 Views, 6 Replies
Hi.
I have both AutoCAD 2006 and 2007 insatlled on my machine. I also have
vs2003 ans vs2005.
Both was working fine.
I was sufing on internet when my pc suddenly hang and I had to swich off the
pc when AutoCAD
2006 was in debug mode thrue VS2003.
After that it takes over 7 minuts to start acad2006 and 3-4 minuts to start
acad2007
It starts fine until it hang up at 99 %. After it has started, it works
fine.
I have reinstalled both, chech searchpaths, clean registry befor reinstalled
and everything looks
fine. I cant understand that both acad 2006 og 2007 is so slow.
Do anybody have any idea what to should try?
Rune
6 REPLIES 6
Try editing your acad.exe.config files to use
the version of the framework for each release
(1.0/1.1 for 2006, and 2.0 for 2007).
That should do it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Rune Aarnes" wrote in message news:5341069@discussion.autodesk.com...
Hi.
vs2003 ans vs2005.
pc when AutoCAD
acad2007
fine.
Rune
It didn't help.....
I unncommend this:
for 2007:
for 2006:
Any more ideas?
"Tony Tanzillo" skrev i melding
news:5341120@discussion.autodesk.com...
That should do it.
Hi.
vs2003 ans vs2005.
pc when AutoCAD
acad2007
fine.
Rune
ko
Community Visitor
i'm having the same configuration & same problem
cpickel
What did you do to correct this problem? I am having the same problem.
cpickel
I am having this same problem. What did you do to correct it?
Brockster
Did anyone find an answer to this problem?
”Boost
