.NET
****!!!REALLY SIMPLE C#/AUTOCAD QUESTION!!!*** Manipulate a drawing
5 REPLIES 5
lbayas
355 Views, 5 Replies
Hi-
I am writing a really simple C# application. It basically takes values and puts them into an autocad drawing. Right now I am able to to open an AutoCAD drawing but I am having trouble manipulating it the way I would like. The following code below is what I have so far:
gbl_app = new AcadApplication();
gbl_doc = gbl_app.ActiveDocument;
gbl_doc.Open(AcadFile, password);
gbl_app.Application.Visible = true;
My next step is to grab all the text objects in gbl_doc and change them, does anyone know what my next step should be? Should I be using a "Selection Set" for this? Thanks a bunch
5 REPLIES 5
in reply to: lbayas
Your next step should be going to buy a textbook from Deitel & Deitel and
learn how to use C#. I would also recommend that you use the web to find and
adopt Microsoft's C# naming conventions. Drop your bad habits now. Once you
learn how to use C# you should then start learning the .NET Framework noting
most of the important documentation is at msdn2.microsoft.com which has been
dysfunctional for a couple of months now but you can still find lots of
documentation for C# at msdn.microsoft.com.
Meanwhile, what you want to do is set up a foreach loop passing gbl_doc as
the parameter. Inside the loop you use the GetType( ) method to test for the
type of object you are looking for. When you find the type of object you
want you can do something with it.
<%= Clinton Gallagher
NET csgallagher AT metromilwaukee.com
URL http://clintongallagher.metromilwaukee.com/
MAP http://wikimapia.org/#y=43038073&x=-88043838&z=17&l=0&m=h
wrote in message news:5429174@discussion.autodesk.com...
Hi-
in reply to: lbayas
>> foreach loop passing gbl_doc as the parameter.
>> to test for the type of object you are looking for.
>> When you find the type of object you want you
Perhaps you should refrain from advising others
on how to go about doing things, that you quite
obviously, don't know how to do yourself.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
in reply to: lbayas
It it depends on where the text objects you want
to process are located. If they're in model space
or a paper space layout, you can use a selection
set to collect them, and then process the selection
set.
Hi-
lbayas
in reply to: lbayas
First off -- Mr. Clinton Gallagher, I am well-versed in C#, more so than you are with those cheap looking websites you make for a living. Why don't you try to answer the question instead of criticizing others on convention.
Now back to business. Thanks Tony for actually answering my AutoCAD related question. So I will have to use selection sets to obtain the text from my layout. I believe I am in "paper space layout" with a 2-D drawing.
in reply to: lbayas
dang, you are swimming with the sharks now!
lbayas <>
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
”Boost
