When providing an application packed with a licencied copy RealDWG , what sort of copyright information
should the application display ?
Best Regards aamara.
Aamara -
The information can be found in your RealDWG 2015 SDK license agreement together with the contents of 'RealDWG Logo and AutoCAD DWG Icon Use' section in the Autodesk RealDWG 2015 Readme:
by default in this location C:\Program Files\Autodesk\RealDWG 2015\Docs\readdbx.chm
Cheers,
Paavo
To help readers who don't have RealDWG installed, I copy licensing info from the file readdbx.chm:
RealDWG Licensing
The RealDWG® 2015 libraries may only be used by developers who have licensed the RealDWG 2015 software from Autodesk, Inc. Permissible use of the software is defined in the license agreement. If you do not have a license agreement in place with Autodesk, Inc., please download the application at www.autodesk.com/realdwg and submit it to the appropriate contact.
Information on RealDWG 2015 can also be found at www.autodesk.com/realdwg. Unauthorized use, distribution, or implementation of RealDWG 2015 will be prosecuted to the fullest extent of the law.
The following guidelines for using the RealDWG® 2015 logo and AutoCAD® DWG icon apply to parties licensing RealDWG 2015. Please refer to your RealDWG 2015 SDK license agreement for the exact requirements.
Logo Usage Guidelines
The RealDWG 2015 logo is used to identify and promote RealDWG 2015 technology. Use of the logo is limited to parties under license from Autodesk, Inc. as outlined in the section below.
Licensee will place the Autodesk copyright and, whenever possible, the RealDWG 2015 logo in the following areas of licensee product or service:
The RealDWG images are located in C:\Program Files\Autodesk\RealDWG 2015\Redistrib directory.
Installation and Start-up Attribution
Licensee will make the RealDWG 2015 logo visible and readable during the installation or startup screens of licensee product or service.
DWG and DXF Icon
If not already registered, the application using RealDWG must register with the file system the Autodesk DWG and DXF icons (installed in the Redistrib directory) are using. The application must use these icons when displaying DWG and DXF files within the application.
Default Application
If an Autodesk application is installed and is the default launch application for the DWG file format, the licensee’s application must not register itself as the default launch application for opening DWG or DXF files.
File Operation Dialog Boxes
Any dialog or interface that uses RealDWG 2015 to read or write DWG or DXF files must indicate that it is using RealDWG 2015 technology to read or write these files. An example would be to place "RealDWG (*.dwg)" or "RealDWG (*.dxf)" in the file type area of the interface.
