Dear All,
We had build a Application with RealDWG 2012. Unfortunately, the applicaton can't be run correctly, if the computer havn't install at least one product of Autodesk.
if we had install DWG Trueview, or Design Review, or Vault client, AutoCAD, the applicaiton correctly.
Autodesk's product had been installed is the basic requirement of RealDWG 2012 applications?
My Regards,
Rick
The fact that installing another Autodesk product fixes your app implies you've not correctly followed the instructions in the RealDWG helpfiles on creating your installer and adding the correct RealDWG and Microsoft merge modules to it.
Thanks, Stephen.
attachment is our sample application with Merge module and setup project.
we did the merge modules as the readdbx.chm, there 7 module at least, and with 3 microsoft merge modules.
Would you pls help us check what wrong with it?
Many thanks for your supports.
Rick
Are you an ADN member? If so, please submit this question via DevHelp Online on the ADN website.
Yes, We are ADN Member.
And I had summit it and waiting for the reply. Thanks again!
