.NET
Reading/writing to .dwg files without AutoCAD?
3 REPLIES 3
murrdpirate
3721 Views, 3 Replies
Is this possible?  I was trying to make a simple windows program that prompted the user to select a .dwg file and the program would list all the layers in a listbox.  But the Database.ReadDWGFile procedure doesn't appear to work outside of AutoCAD (FileNotFound Exception).  Can I have my windows program open AutoCAD in the background to achieve this?
Here's my code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class Form1
    Dim myLayers As ArrayList
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim myDB As New Database(False, True)
        myDB.ReadDwgFile("C:\test.dwg", FileOpenMode.OpenForReadAndAllShare, True, "")
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
            Dim myLayerTable As LayerTable = myDB.LayerTableId.GetObject(OpenMode.ForRead)
            Dim layerName As String = ""
            For Each myObjectID As ObjectId In myLayerTable
                Dim myLayer As LayerTableRecord = myObjectID.GetObject(OpenMode.ForRead)
                myLayers.Add(myLayer.Name)
            Next
            myTrans.Abort()
        End Using
        myDB.Dispose()
        For Each layerxx In myLayers
            ListBox1.Items.Add(layerxx)
        Next
    End Sub
End Class
3 REPLIES 3
Is this possible?
No.
Yes.
You can only use ActiveX interface of AutoCAD from external application, e.g.
Autodesk.Autocad.Interop and
Autodesk.Autocad.Interop.Common
arcticad
in reply to: AlexanderRivilis
You can use either AutoDesk  RealDWG
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
or Teigha™.NET for .dwg files
http://www.opendesign.com/
To modify files without Autocad.
These are both pay options.
The only free options is to have Autocad Installed and use ActiveX.
(defun botsbuildbots() (botsbuildbots))
murrdpirate
in reply to: murrdpirate
Sweet.  Many thanks to both of you.
”Boost
