.NET
insiaiftiqhar
Message 1 of 3 (218 Views)
reading geomeric constraints
218 Views, 2 Replies
11-28-2012 01:55 PM
How do you read geometric constraints from the Assoc2dConstraintGroup in C# or VB?
Hi There,
Here is a c# sample that illustrates how to get started:
[CommandMethod("DumpConstraints")]
public void DumpConstraints()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
ObjectId networkId = AssocNetwork.GetInstanceFromObject(
db.CurrentSpaceId,
false,
true,
"ACAD_ASSOCNETWORK");
if (networkId == ObjectId.Null)
return;
using (Transaction Tx =
db.TransactionManager.StartTransaction())
using (AssocNetwork network =
Tx.GetObject(
networkId,
OpenMode.ForRead, false) as AssocNetwork)
foreach (ObjectId actionId in network.GetActions)
if (actionId == ObjectId.Null)
continue;
DBObject obj = Tx.GetObject(
actionId,
OpenMode.ForRead);
//ed.WriteMessage("\n - Action: " + obj.ToString().Remove(0, 34));
if (actionId.ObjectClass.IsDerivedFrom(
RXObject.GetClass(
typeof(Assoc2dConstraintGroup))))
Assoc2dConstraintGroup group = obj
as Assoc2dConstraintGroup;
foreach(GeometricalConstraint constraint
in group.Constraints)
//... do something ...
Philippe.
ADN Support Specialist
philippe.leefsma
Message 2 of 3 (183 Views)
Re: reading geomeric constraints
12-04-2012 01:10 AM in reply to: insiaiftiqhar
Hi There,
        db.CurrentSpaceId,
        false,
        true,
        return;
            Tx.GetObject(
                networkId,
                    continue;
                    actionId,
                    OpenMode.ForRead);
                    RXObject.GetClass(
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
insiaiftiqhar
Message 3 of 3 (166 Views)
12-04-2012 12:34 PM in reply to: philippe.leefsma
I can't thank you enough for helping me. I had given up and was working on an alternate/not so elegant solution. Thank you SO very much!
