.NET
reading geomeric constraints
2 REPLIES 2
764 Views, 2 Replies
How do you read geometric constraints from the Assoc2dConstraintGroup in C# or VB?
2 REPLIES 2
philippe.leefsma
Hi There,
Here is a c# sample that illustrates how to get started:
[CommandMethod("DumpConstraints")]
public void DumpConstraints()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    ObjectId networkId = AssocNetwork.GetInstanceFromObject(
        db.CurrentSpaceId,
        false,
        true,
        "ACAD_ASSOCNETWORK");
    if (networkId == ObjectId.Null)
        return;
    using (Transaction Tx =
        db.TransactionManager.StartTransaction())
        using (AssocNetwork network =
            Tx.GetObject(
                networkId,
                OpenMode.ForRead, false) as AssocNetwork)
            foreach (ObjectId actionId in network.GetActions)
                if (actionId == ObjectId.Null)
                    continue;
                DBObject obj = Tx.GetObject(
                    actionId,
                    OpenMode.ForRead);
                //ed.WriteMessage("\n - Action: " + obj.ToString().Remove(0, 34));
                if (actionId.ObjectClass.IsDerivedFrom(
                    RXObject.GetClass(
                        typeof(Assoc2dConstraintGroup))))
                    Assoc2dConstraintGroup group = obj
                        as Assoc2dConstraintGroup;
                    foreach(GeometricalConstraint constraint
                        in group.Constraints)
                        //... do something ...
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
in reply to: philippe.leefsma
I can't thank you enough for helping me. I had given up and was working on an alternate/not so elegant solution. Thank you SO very much!
”Boost
