.NET
reading AttributeDefinition
15 REPLIES 15
Message 1 of 16
770 Views, 15 Replies
hi all,
I have a block that have two attributes( description and amount) the user can fill these in when inserting the block. i can read the Tag and the Prompt, but when i read the textstring it return nothing.
anyone an idea, how do I read the value of the tag.
thanks in advance
15 REPLIES 15
Message 2 of 16
Be sure you are getting the AttributeReference objects from the
BlockReference object's GetAttributes method.
R. Robert Bell
wrote in message news:5244546@discussion.autodesk.com...
hi all,
thanks in advance
Message 3 of 16
Huh ?
What "GetAttributes" method ????
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"R. Robert Bell" wrote in message news:5244711@discussion.autodesk.com...
R. Robert Bell
hi all,
thanks in advance
Message 4 of 16
You're confusing AttributeDefinition and AttributeReference.
The former appears in the block definition and acts as
a template for creation of the latter, which appears in
each reference/insertion of the block (BlockReference).
You need read the TextString property of the attribute
reference (AttributeReference class). There is one of
these for each attribute, which is accessed via the
AttributeCollection property of the owning BlockReference.
hi all,
thanks in advance
Message 5 of 16
Sorry, I missed what group I was in.
R. Robert Bell
"Tony Tanzillo" wrote in message
news:5244769@discussion.autodesk.com...
Huh ?
Message 6 of 16
hi,
so i need to read the attrbuteReference, do you have a sample code VB.net or C#.
now i'm doing this
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
'CType(trans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
'CType(trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead), BlockTableRecord)
Dim id As ObjectId
Dim idnr As Int32
Dim attref As AttributeReference = New AttributeReference()
idnr = 0
For Each id In btr
Dim ent As Entity = trans.GetObject(id, OpenMode.ForRead, False)
'CType(trans.GetObject(id, OpenMode.ForRead, False), Entity)
If TypeOf ent Is BlockReference Then
Dim saEmployeeList(-1) As String
Dim Blk As BlockReference = CType(ent, BlockReference)
Dim br As BlockTableRecord = CType(trans.GetObject(Blk.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
blockname = br.Name
'ListBlocks(id, saEmployeeList, blockname)
Dim sEmployeeData As String
Dim empBtr As BlockTableRecord = trans.GetObject(bt(blockname), OpenMode.ForRead)
ac = Blk.AttributeCollection
Dim entid As ObjectId
For Each entid In empBtr
Dim entt As Entity = trans.GetObject(entid, OpenMode.ForRead, False)
If TypeOf entt Is AttributeDefinition Then
Dim attDef As AttributeDefinition = CType(entt, AttributeDefinition)
attref.SetPropertiesFrom(attDef)
attref.Tag = attDef.Tag
ed.WriteMessage("Block tag = " + attDef.Tag + ControlChars.Lf)
ed.WriteMessage("Tag String = " + " " + attDef.Prompt + ControlChars.Lf)
ed.WriteMessage("Tag String = " + " " + attDef.TextString + ControlChars.Lf)
Next
the above code just give me the Tag and prompt, thanks
Message 7 of 16
hi,
ops srry it didn't work, if you have any examble pls send them to me
Message was edited by: pipo2007 Message was edited by: pipo2007
Message 8 of 16
In that case, you have the wrong class names
('BlockReference' and 'AttributeReference'), which
are the proper names of the managed wrapper
classes, but don't exist in ActiveX/VBA.
Message 9 of 16
hi Tony,
I get the AttrbuteRefrence of a block, and I get the Tag and value that are constants of the block.
but only two tag's that are must be giving when you insert a block, the description tag and the amount tag, I cant get the value of these tags!!
Message 10 of 16
You can't expect much help without posting
your code.
wrote in message news:5247127@discussion.autodesk.com...
hi Tony,
Message 11 of 16
hi Tony,
sorry this is my code.
_
Public Sub Countblok()
Try
Dim id As ObjectId
Dim idnr As Int32
idnr = 0
For Each id In btr
blockname = br.Name
Dim idreffrence As ObjectId
idreffrence = Blk.AttributeCollection.Item(0)
Dim attRef As AttributeReference = New AttributeReference()
attRef.SetAttributeFromBlock(attDef, Blk.BlockTransform)
attRef.SetPropertiesFrom(attDef)
'attref.Tag = attDef.Tag
ed.WriteMessage("attref tag = " + attRef.Tag + ControlChars.Lf)
ed.WriteMessage("attdef tag = " + " " + attDef.Tag + ControlChars.Lf)
ed.WriteMessage("Tag value = " + " " + attRef.TextString + ControlChars.Lf)
Next
' blocks(i) = blockname
i = i + 1
End Sub
Message 12 of 16
and this is the block that i use, and i want to get the attribute out of it.
thanks
Message 13 of 16
Please go back and read my previous posts.
It explains what you need to do, but you code
does not do that.
wrote in message news:5247195@discussion.autodesk.com...
hi Tony,
_
Try
Dim id As ObjectId
Dim idnr As Int32
idnr = 0
For Each id In btr
blockname = br.Name
Next
i = i + 1
End Sub
Message 14 of 16
Mikko
Is this what your looking for?
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim t As Transaction = db.TransactionManager.StartTransaction()
Dim blkname As String = "E6534-11"
Dim bt As BlockTable = CType(t.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
Dim btr As BlockTableRecord = CType(t.GetObject(bt(blkname), OpenMode.ForRead), BlockTableRecord)
Dim oic As ObjectIdCollection = btr.GetBlockReferenceIds(False, False)
Dim br As BlockReference = CType(t.GetObject(oic(0), OpenMode.ForRead), BlockReference)
Dim ac As Integer = br.AttributeCollection.Count
Dim i As Integer
For i = 0 To ac - 1
Dim ar As AttributeReference
ar = CType(t.GetObject(br.AttributeCollection(i), OpenMode.ForRead), AttributeReference)
MsgBox(ar.TextString)
Next
t.Commit()
t.Dispose()
Message 15 of 16
hi Tony,
I get it now thank you very much.
Message 16 of 16
thanks
I solved the problem know with the same methoud you'r using
”Boost
