.NET
Active Member
0 Kudos
Post 11 of 16
Re: reading AttributeDefinition
07-25-2006 05:29 AM in reply to: pipo2007
hi Tony,
sorry this is my code.
_
Public Sub Countblok()
Try
Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
'CType(trans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
'CType(trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead), BlockTableRecord)
Dim id As ObjectId
Dim idnr As Int32
idnr = 0
For Each id In btr
Dim ent As Entity = trans.GetObject(id, OpenMode.ForRead, False)
'CType(trans.GetObject(id, OpenMode.ForRead, False), Entity)
If TypeOf ent Is BlockReference Then
Dim saEmployeeList(-1) As String
Dim Blk As BlockReference = CType(ent, BlockReference)
Dim br As BlockTableRecord = CType(trans.GetObject(Blk.BlockTableRecord, OpenMode.ForRead, False), BlockTableRecord)
blockname = br.Name
Dim idreffrence As ObjectId
idreffrence = Blk.AttributeCollection.Item(0)
'ListBlocks(id, saEmployeeList, blockname)
Dim sEmployeeData As String
Dim empBtr As BlockTableRecord = trans.GetObject(bt(blockname), OpenMode.ForRead)
ac = Blk.AttributeCollection
Dim entid As ObjectId
For Each entid In empBtr
Dim entt As Entity = trans.GetObject(entid, OpenMode.ForRead, False)
If TypeOf entt Is AttributeDefinition Then
Dim attDef As AttributeDefinition = CType(entt, AttributeDefinition)
Dim attRef As AttributeReference = New AttributeReference()
attRef.SetAttributeFromBlock(attDef, Blk.BlockTransform)
attRef.SetPropertiesFrom(attDef)
'attref.Tag = attDef.Tag
ed.WriteMessage("attref tag = " + attRef.Tag + ControlChars.Lf)
ed.WriteMessage("attdef tag = " + " " + attDef.Tag + ControlChars.Lf)
ed.WriteMessage("Tag value = " + " " + attRef.TextString + ControlChars.Lf)
End If
Next
' blocks(i) = blockname
i = i + 1
End Sub
Active Member
0 Kudos
Post 12 of 16
07-25-2006 05:33 AM in reply to: pipo2007
and this is the block that i use, and i want to get the attribute out of it.
thanks
*Tony Tanzillo
Post 13 of 16
07-25-2006 06:56 AM in reply to: pipo2007
Please go back and read my previous posts.
It explains what you need to do, but you code
does not do that.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5247195@discussion.autodesk.com...
hi Tony,
_
Try
Dim id As ObjectId
Dim idnr As Int32
idnr = 0
For Each id In btr
blockname = br.Name
End If
Next
i = i + 1
End Sub
Distinguished Contributor
6 Kudos
Post 14 of 16
07-25-2006 08:02 AM in reply to: pipo2007
Is this what your looking for?
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim t As Transaction = db.TransactionManager.StartTransaction()
Dim blkname As String = "E6534-11"
Dim bt As BlockTable = CType(t.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
Dim btr As BlockTableRecord = CType(t.GetObject(bt(blkname), OpenMode.ForRead), BlockTableRecord)
Dim oic As ObjectIdCollection = btr.GetBlockReferenceIds(False, False)
Dim br As BlockReference = CType(t.GetObject(oic(0), OpenMode.ForRead), BlockReference)
Dim ac As Integer = br.AttributeCollection.Count
Dim i As Integer
For i = 0 To ac - 1
Dim ar As AttributeReference
ar = CType(t.GetObject(br.AttributeCollection(i), OpenMode.ForRead), AttributeReference)
MsgBox(ar.TextString)
Next
t.Commit()
t.Dispose()
Active Member
0 Kudos
Post 15 of 16
07-26-2006 04:12 AM in reply to: pipo2007
hi Tony,
I get it now thank you very much.
Active Member
0 Kudos
Post 16 of 16
07-28-2006 08:08 AM in reply to: pipo2007
thanks
I solved the problem know with the same methoud you'r using
