.NET
ReadDwgFile
0 REPLIES 0
Message 1 of 1
nlvvch
266 Views, 0 Replies
ReadDwgFile
Hi, Iam unable to run the following code, can u please suggest better way. Iam not able understatinding what I did the mistache i search lot site just they using the following lines of code and the same code while Iam trying my pc here Iam gettting the err: an Unhandle exception.
can u please give me solution for inserting block external from the directory into active document.
thanks and regards
venkatesh
using (Database db = new Database(false, true))
try
db.ReadDwgFile(res.StringResult, System.IO.FileShare.Read, true, "");
catch (Autodesk.AutoCAD.Runtime.Exception ex)
ed.WriteMessage(
"\nUnable to read drawing file.\n " + ex.Message
return;
0 REPLIES 0
”Boost
