.NET
GeeHaa
Message 1 of 10 (582 Views)
ReadDWGFile Slow in ACAD2013
582 Views, 9 Replies
06-12-2013 10:32 AM
I recently converted a vb.net program that extracts attribute data to work with ACAD2013. The program runs but is very slow It takes a full 10 minutes to read 120 small dwg files. The same program running in ACAD2010 takes about 3 seconds. Has anyone else run into this?
Thanks in Advance
G.
I added your recommendations but it still crashes with the following error at around 1600 drawings out of 2100.
System.AccessViolationException was unhandled
  Message=Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
  Source=Acdbmgd
  StackTrace:
       at Autodesk.AutoCAD.Runtime.RXObject.DeleteUnmanagedObject()
       at Autodesk.AutoCAD.Runtime.DisposableWrapper.!DisposableWrapper()
       at Autodesk.AutoCAD.Runtime.DisposableWrapper.Dispose(Boolean )
  InnerException:
You do not need to explicitly dispose your transaction as you're using a 'Using' block.
You might dispose the side Database too.
Using acCurDB As New Database(False, True)
acCurDB.ReadDwgFile(listOfFiles(x), FileOpenMode.OpenForReadAndReadShare, True, "")
Using acTrans As Transaction = acCurDB.TransactionManager.StartTransaction
End Using
End Using
ADN Support Specialist
fenton.webb
Message 2 of 10 (530 Views)
Re: ReadDWGFile Slow in ACAD2013
06-19-2013 08:36 AM in reply to: GeeHaa
can you send us some sample code please? I'd like to test it for you to see where the problem is.
Fenton Webb
Developer Technical Services
Autodesk Developer Network
GeeHaa
Message 3 of 10 (526 Views)
06-19-2013 09:20 AM in reply to: GeeHaa
For x As Integer = 0 To UBound(listOfFiles)
            Dim layoutStrings() As String = Nothing
            Dim acCurDB As New Database(False, True)
                Dim acLayoutMgr As LayoutManager
                acLayoutMgr = LayoutManager.Current
                 Dim layoutdict As DBDictionary = acTrans.GetObject(acCurDB.LayoutDictionaryId, OpenMode.ForRead)
                ReDim layoutStrings(layoutdict.Count - 2)
                For Each Ent As DBDictionaryEntry In layoutdict
                    Dim desc_Txt As String = ""
                    Dim lay As Layout = acTrans.GetObject(Ent.Value, OpenMode.ForRead)
                    Dim layBTRId As ObjectId = lay.BlockTableRecordId
                    Dim btr As BlockTableRecord = TryCast(layBTRId.GetObject(OpenMode.ForRead), BlockTableRecord)
                    If (Not lay.LayoutName = "Model") Then
                        myWS.Cells(curRow, "D") = File.GetLastWriteTime(listOfFiles(x))
                        For Each entId3 As ObjectId In btr
                            Dim ent3 As Entity = entId3.GetObject(OpenMode.ForRead)
                            Dim nextRow As Boolean = False
                            If TypeOf ent3 Is DatabaseServices.BlockReference Then
                                Dim bref As BlockReference = ent3
                                Dim atts As AttributeCollection = bref.AttributeCollection
                                For Each attId As ObjectId In atts
                                    Dim AttRef As AttributeReference = attId.GetObject(OpenMode.ForRead)
                                    Select Case AttRef.Tag
                                        Case getTags(0)
                                            If Trim(AttRef.TextString) <> "" Then
                                                myWS.Cells(curRow, "A") = AttRef.TextString
                                                myWS.Cells(curRow, "J") = fixDwgName(AttRef.TextString)
                                                myWS.Cells(curRow, "G") = ListOfNames(x)
                                            End If
                                        Case getTags(1)
                                                myWS.Cells(curRow, "C") = Trim(AttRef.TextString)
                                            End If
        Case getTags(2)
                                                myWS.Cells(curRow, "E") = Trim(AttRef.TextString)
                                            End If
                                        Case getTags(3)
                                                myWS.Cells(curRow, "F") = Trim(AttRef.TextString)
                                            End If
                                     End Select
                                Next attId
                                Dim tempstr As String = ""
                                For x2 As Integer = 4 To getTags.Count - 1
                                        If AttRef.Tag = getTags(x2) Then
                                            tempstr = tempstr + AttRef.TextString + " "
                                        End If
                                    Next attId
                                Next
                                If (Not Trim(tempstr) = "") Then
                                    myWS.Cells(curRow, "B") = Trim(tempstr)
                                End If
                                If nextRow = True Then
                                     curRow += 1
                                End If
                            End If
                            'End If 'invp
                        Next entId3
                        curRow += 1
                    End If
                    'MsgBox("layoutname = " + lay.LayoutName)
                Next
                acTrans.Dispose()
            End Using
            acCurDB.CloseInput(True)
        Next
 Here it is Some of it. I hope it's all you need.
Thanks Very Much
fenton.webb
Message 4 of 10 (519 Views)
06-19-2013 11:49 AM in reply to: GeeHaa
remove closeInput and also try changing the open mode to just read (no sharing)
Fenton Webb
Valued Mentor
jeff
Message 5 of 10 (510 Views)
06-19-2013 01:06 PM in reply to: fenton.webb
Try commiting your transaction instead of disposing it which will call Abort
http://www.theswamp.org/index.php?topic=44037.msg493005#msg493005
You can also find your answers @ TheSwamp
GeeHaa
Message 6 of 10 (505 Views)
06-19-2013 02:56 PM in reply to: GeeHaa
Removing CloseInput helped. Still Not as fast as 2010 and it crashes at about 1600 drawings always on a different drawing though. Is anything else wrong that you can see? I also committed the Transaction instead of disposing it
Thanks Again
fenton.webb
Message 7 of 10 (502 Views)
06-19-2013 03:02 PM in reply to: GeeHaa
make sure you set the workingDatabase. Also, if you are not writing anything I recommend you use StartOpenCloseTransaction instead of StartTransaction
Fenton Webb
GeeHaa
Message 8 of 10 (478 Views)
06-20-2013 12:19 PM in reply to: GeeHaa
  Source=Acdbmgd
  StackTrace:
  InnerException:
_gile
Message 9 of 10 (459 Views)
06-21-2013 06:13 AM in reply to: GeeHaa
    End Using
End Using
Gilles Chanteau
GeeHaa
Message 10 of 10 (427 Views)
06-24-2013 11:14 AM in reply to: GeeHaa
Disposing of the side database worked. AS far as speed goes I was running the program in Debug Mode. The release version is as fast as 2010 if not faster.
Thanks Again
