.NET
Valued Contributor
2 Kudos
Post 1 of 2
ReadDwgFile fatal error Map3d 2014
159 Views, 1 Replies
03-07-2014 10:11 AM
I'm trying to open a file in vb.net to read some of the xrefs within it, and I have narrowed down the fatal error that is being generated by the following code.   I have tried both of the differences I have listed below and both produce a fatal error when the ReadDwgFile is envoked.  Can someone tell me why that may be happening?
 Dim myDB As New Autodesk.AutoCAD.DatabaseServices.Database
        myDB.ReadDwgFile(dwgfile, FileOpenMode.OpenForReadAndWriteNoShare, False, "")
Or this:
        myDB.ReadDwgFile(dwgfile, IO.FileShare.ReadWrite, True, "")
I solved my issue thanks to this post here
I'm no pro at the new .Net api so I'm still muddling my way around.  however, the issue appears to be how I was creating the db.   The change I made is shown below which has solved my issue:
Dim myDB As New Autodesk.AutoCAD.DatabaseServices.Database(False, True)
myDB.ReadDwgFile(dwgfile, FileShare.ReadWrite, False, String.Empty)
Valued Contributor
2 Kudos
Post 2 of 2
Re: ReadDwgFile fatal error Map3d 2014
03-07-2014 10:54 AM in reply to: frosty1_4me
