.NET
Read vertices of a polyline
4 REPLIES 4
9476 Views, 4 Replies
I need to read all vertices of a polyline and extract coordinates.
Could you please tell me how to do that in VB.NET?
Thanx,
4 REPLIES 4
VB.Net code -
 Public Shared Function getAllVertices(ByVal ent As Polyline) As Point2dCollection
        Dim verCollection As Point2dCollection = New Point2dCollection()
        Dim vertex As Point2d
        Dim i As Integer = 0
        For i = 0 To ent.NumberOfVertices - 1
            vertex = ent.GetPoint2dAt(i)
            verCollection.Add(vertex)
        Next
        Return verCollection
    End Function
    Public Shared Function getAllVertices(ByVal ent As Polyline) As Point2dCollection        Dim verCollection As Point2dCollection = New Point2dCollection()        Dim vertex As Point2d        Dim i As Integer = 0        For i = 0 To ent.NumberOfVertices - 1            vertex = ent.GetPoint2dAt(i)            verCollection.Add(vertex)        Next        Return verCollection    End Function
Thank you for the response.
In fact, I need to read vertices of 3D Polylines and have problems finding NumberOfVertices property...
Could you suggest me in this regard? Thanx,
chiefbraincloud
Depending on circumstances, in the past I have used Polyline3d.GetStretchPoints.  You pass it an empty Point3dCollection and it fills the collection.
That said, it doesn't work when the polyline is not db resident, and I'm not sure what it would do if the Polyline was not type SimplePoly, so, this is another way.
For I as Integer = 0 to Poly3d.EndParam
      PointCol.Add (Poly3d.GetPointAtParameter(I))
Next I
This is a way to do it:
Sub Read3DPolyline(ByVal poly3d As Polyline3d)
        '' Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim vId As ObjectId
            For Each vId In poly3d
                Dim v3d As PolylineVertex3d = acTrans.GetObject(vId, OpenMode.ForRead)
                acDoc.Editor.WriteMessage(vbCrLf + v3d.Position.ToString())
            Next
            acTrans.Commit()
        End Using
    End Sub
”Boost
