.NET
READ PaperSpace Viewport viewtarget
1 REPLY 1
dancalgary
870 Views, 1 Reply
I have an existing viewport (viewport1) on paperspace.
Viewport1.ViewDirection = Autodesk.AutoCAD.Geometry.Vector3d.ZAxis
I am trying to create a new viewport (viewport2) that is placed above it and to have the same properties except twist angle.
But I fail because of viewtarget.
The view is not pointing to the same point.
Can somebody corrects me?
                                    Dim Viewport2 As New Viewport
                                    Viewport2.SetDatabaseDefaults()
                                    Viewport2.CenterPoint = New Point3d(Viewport1.CenterPoint.X, Viewport1.CenterPoint.Y + 10 + Viewport1.Height, 0)
                                    Viewport2.Height = Viewport1.Height + 10
                                    Viewport2.Width = Viewport1.Width + 10
                                    Viewport2.ColorIndex = 1
                                    Viewport2.ViewDirection = Autodesk.AutoCAD.Geometry.Vector3d.ZAxis
                                    Viewport2.ViewTarget = Viewport1.ViewTarget
                                    Viewport2.ViewCenter = Point2d.Origin
                                    Viewport2.TwistAngle = pi/2
                                    PaperSpace.AppendEntity(Viewport2)
                                    Trans1.AddNewlyCreatedDBObject(Viewport2, True)
                                    Viewport2.On = True
                                    Viewport2.CustomScale = Viewport1.CustomScale
                                    Viewport2.Locked = True
1 REPLY 1
in reply to: dancalgary
The most annoying thing when programming with autocad is the viewports, really their api sucks soo much. I have also a similar problem, I clone an existing viewport using the clone method but it doesnt work!!! I dont have any idea on how to copy or clone a viewport.
”Boost
